Ātrā meklēšana
Produkta iespējas:
Indoor 2.4GHz Directional Antenna
Apraksts:
The ANT24-0600 2.4GHz Directional Antenna is a range extender antenna that provides output 2 to 2.5 times higher than that of the 2dBi dipole antennas normally bundled with wireless LAN devices.
This directional antenna is suitable for indoor use only and can substantially improve signal transmission strengths* at sites where the default antenna of the wireless device is weak due to environmental or structural condditions.
The ANT24-0600 antenna works with all access points and remote routers equipped with an RP-SMA or RP-TNC connector. Installation is a simple two step process and can be done in a few minutes.
The ANT-24-0600 antenna offers several mounting options, it can be placed on a flat surface, such as on a desktop, mounted flat against a wall, or attached vertically to a flat surface, such as a metal door, using its magnetic mounting base.
The antenna design provides a focused wireless signal with 80 degree spread, allowing it to be tilted to a desired angle to produce the most effective signal transmission result.
* Signal strengths are subject to environmental conditions.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
