Ātrā meklēšana
Produkta iespējas:
Xtreme N Notebook Expresscard
Apraksts:
ULTIMATE PERFORMANCE
The D-Link Xtreme N Notebook ExpressCard DWA-643 is a draft 802.11n compliant wireless client for notebook PC with available ExpressCard slots. This wireless adapter delivers much faster speeds and many times farther range than 802.11g while staying backward compatible with 802.11g and 802.11b networks. Once connected, you can share a high-speed Internet connection, photos, fles, music, printers, and more. In addition, the ExpressCard interface provides much faster performance and better reliability than the legacy CardBus interface. Having an ExpressCard/34 form factor, the DWA-643 will ft into any standard ExpressCard slot.
GET CONNECTED, STAY CONNECTED
The Xtreme N Notebook ExpressCard is powered by Xtreme N technology to provide superior wireless performance in the home or offce. This adapter is designed for use in larger homes and offces, or for users running multiple bandwidth-intensive applications. This adapter enables you to simultaneously make or receive Internet phone calls (VoIP), surf the Web, transfer fles, and stream High-Defnition (HD) media when connected to a draft 802.11n router, such as the DIR-655 router. The DWA-643 ExpressCard supports WEP, WPA, and WPA2 encryption that allow you to connect securely to a wireless network.
EASY TO SET UP, EASY TO USE
D-Link’s Quick Adapter Setup Wizard guides you step-by-step through the installation process. Confgure this notebook ExpressCard without having to call a networking expert to help you. The D-Link Wireless Manager is also included with this product to keep track of your most frequently accessed networks so that you can join them quickly and easily. With unmatched wireless performance, reception, and security, the DWA-643 D-Link Xtreme N Notebook ExpressCard is the best choice for easily adding or upgrading wireless connectivity to your ExpressCard-enabled notebook PC.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
