Ātrā meklēšana
Produkta iespējas:
WIRELESS G NOTEBOOK ADAPTER
Apraksts:
BASIC WIRELESS CONNECTIVITY
Connect to your wireless network from your notebook PC using the DWA-610 Wireless G Notebook Adapter and browse the web, check e-mail, and chat with friends and family online. The Wireless G Notebook Adapter offers simple network connectivity without the hassle of running a network cable.
BASIC SECURITY PROTECTION
To protect your data and privacy, the Wireless G Notebook Adapter supports WEP and WPA encryption for connecting to a secure wireless network.
COMPATIBILITY ASSURANCE
The Wireless G Notebook Adapter is based on the 802.11g standard and is backwards compatible with 802.11b, ensuring compatibility with a wide range of wireless routers and networks.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup for this notebook adapter. The addition of the Wi-Fi Protected Setup (WPS) function provides advanced security features that remain simple enough for the average user to confgure correctly. This function allows for devices to undergo an easy one-time click-button confguration for establishing connection with an access point or wireless router without the need of manually setting up complex encryption codes.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
