Ātrā meklēšana
Produkta iespējas:
WIRELESS G ROUTER
Apraksts:
BASIC WIRELESS NETWORKING
Create a wireless network for your home using the D-Link Wireless G Router. Connect the Wireless G Router to a broadband modem and wirelessly share your high-speed Internet connection and enjoy surfi ng the web, checking e-mail, and chatting with family and friends online.
BASIC SECURITY PROTECTION
The D-Link Wireless G Router includes a built-in fi rewall that safeguards your network from harmful attacks. It minimizes the threats of hackers and prevents unwanted intruders from entering your network. Additional security features like MAC address fi ltering prevent unauthorized network access, and parental control prevents users from viewing inappropriate content. The Wireless G Router also supports WEP, WPA, and WPA2 encryption to keep your network traffic secure.
COMPATIBILITY ASSURANCE
The D-Link Wireless G Router is based on the 802.11g standard and is backward compatible with 802.11b, ensuring compatibility with a wide range of wireless devices. The Wireless G Router includes four Ethernet ports ready for you to connect Ethernet-enabled PC, print server and other devices.
EASY TO INSTALL AND USE
With D-Link Quick Router Setup Wizard, you can set up your wireless network in minutes. The wizard will guide you through an easy to follow process to install your new hardware, connect to your network and add new devices. It confi gures your Internet Service Provider (ISP) settings to quickly establish broadband Internet connectivity. In addition, the DIR-300 is Wi-Fi Protected Setup™ (WPS) certifi ed, making it even easier to confi gure your wireless network and enable security.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
