Ātrā meklēšana
Produkta iespējas:
Unified Services Router
Īpašības:
Interface
• Ethernet:
  • 10/100 Mbps WAN Port
  • 8 10/100 Mbps LAN Ports
• Wireless(1):
  • 802.11b/g/n (Single Band)
  • 2 fixed 2dBi Omni-Directional Antennas
• USB 2.0 Ports: 1
• Console: 1 RJ-45
System Performance(6)
• Firewall Throughput(5): 45 Mbps
• VPN Throughput(7): 25 Mbps
• Concurrent Sessions: 20.000
• New Sessions (per second): 200
• Firewall Policies: 200
Internet Connection Type
• Static/ Dynamic IP
• PPPoE/ L2TP/ PPTP
• Multiple PPPoE
Firewall System
• Static Route
• Dynamic DNS
• Inter-VLAN Route
• NAT, PAT
• Web Content Filtering: Static URL, Keywords
Networking
• DHCP Server/ Client
• DHCP Relay
• IEEE802.1q VLAN
• VLAN (Port-Based)
• IP Multicast: IGMP Proxy
• IPv6
• 3G Redundancy
Wireless(1)
• Multiple Service Set Identifier (SSID)
• Service Set Identifier (SSID) to VLAN Mapping
• Standards: 802.11b/g/n
• Wireless Security:
  • Wired Equivalent Privacy (WEP)
  • Wi-Fi Protect Setup (WPS)
  • Wi-Fi Protected Access – Personal (WPA-PSK)
  • Wi-Fi Protected Access – Enterprise (WPA-EAP)
  • Wi-Fi Protected Access version 2 – Personal (WPA-PSK)
  • Wi-Fi Protected Access version 2 – Enterprise (WPA-EAP)
Virtual Private Network (VPN)
• VPN Tunnels: 21
• IPSec Tunnels: 10
• SSL VPN Tunnels: 1
• PPTP/L2TP Clients: 10
• Encryption Methods: DES, 3DES, AES, Twofish, Blowfish, CAST-128, NULL
• SSL Encryption Methods: RC4-128, 3DES, AES
• IPSec/PPTP/L2TP Server
• IPSec NAT Traversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
Bandwidth Management
• Max. Bandwidth Control
• Priority Bandwidth Control:
  • Port-Based QoS
  • 3 Classes
System Management
• Web-based User Interface: HTTP, HTTPS
• Command Line
• SNMP: v1, v2c, v3
Fiziskie raksturlielumi
• Power Supply:
  • External Power Supply Unit, DC 12 V/1.5 A
• Max. Power Consumption: 7.44 W/ 10.5 W
• Dimensions (L x W x H): 208 x 118 x 35 mm
• Operation Temperature: 0 to 40°C
• Storage Temperature: -20 to 70°C
• Operation Humidity: 5% to 95% non-condensing
• EMI/EMC: FCC Class B, CE Class B, C-Tick, IC
• Safety: cUL, LVD (EN60950-1)
• MTBF: 240,000 hours
(1) DSR-150N/250N/500N/1000N only.
(2) DSR-1000N only.
(3) The following 3G dongles are supported: DWM-152 A1/A2/A3, DWM-156 A1/A2/A3/A5*/A6*, DWM-157*, Huawei E1550, E173, and EC306.* The dongles marked with * will be supported through firmware upgrades.
(4) Available through firmware upgrade.
(5) VPN throughput is measured using UDP traffic with a 1420 byte packet size, adhering to RFC2544.
(6) The maximum firewall throughput is based on RFC2544 testing methodologies.
(7) Actual performance may vary depending on network conditions and activated services.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
