DWR-921EOL EOS
4G LTE Router
Apraksts
D-Link’s DWR-921 4G LTE Router allows you to access worldwide mobile broadband networks from anywhere in the world. Once connected, you can transfer data, stream media, and send SMS messages. Simply insert your USIM card and share your 3G/4G Internet connection through a secure wireless network or by using any of the four 10/100 Ethernet ports.
Fast Mobile Internet
The 4G LTE Router lets you connect to your 3G/4G mobile connection with fast downlink speeds of up to 100 Mbps and uplink speeds up to 50 Mbps, giving you the speed you need for fast, responsive Internet access. Surf the web with ease and stream music and video over the Internet to your PCs and mobile devices.
Secure Wired and Wireless Connections
The DWR-921 utilizes dual-active firewalls (SPI and NAT) to prevent potential attacks across the Internet. WPA/WPA2 wireless encryption keeps your wireless network secure and your traffic safe, allowing you to securely share your 3G/4G connection without worrying about unauthorized users accessing your network.
Easy to Set Up and Use
The DWR-921 4G LTE Router can be installed quickly and easily almost anywhere. This router is great for situations where an impromptu wireless network must be set up, or wherever conventional network access is unavailable. The DWR-921 can even be installed in buses, trains, or boats, allowing passengers to check e-mail or chat online while commuting or traveling.
Īpašības
Device Interfaces
• Four 10/100 Ethernet LAN ports
• Two detachable 3G/4G antennas
• WAN (RJ-45) port
Data Rates
• Up to 150 Mbps with 802.11n clients
• 6/9/11/12/18/24/36/48/54 Mbps in 802.11g mode
• 1/2/5.5/11 Mbps in 802.11b mode
• LTE Uplink: Up to 50 Mbps
• LTE Downlink: Up to 100 Mbps
Standards
• 802.11g/b, compatible with 802.11n
• 802.3u
• 802.3
UMTS/HSDPA/HSUPA Band
• 900/2100 MHz
• Power Class 3
LTE Band
• 900/1800/2600/800 MHz
Functionality
Wireless Security
• 64/128-bit WEP (Wired Equivalent Privacy)
• WPA & WPA2 (Wi-Fi Protected Access)
Firewall
VPN
• L2TP/PPTP/IPSEC VPN Pass-through
LED Status Indicators
• WAN
• 3G
• LAN
• SMS
• WLAN
• Signal
• 4G
Dimensions
• 190 x 111.5 x 23.5 mm (7.48 x 4.39 x 0.93 inches)
Weight
• 500 grams (1.10 lb)
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
Humidity
Certifications
• CE
• Wi-Fi Certified
Sertifikāti
Informācija pasūtījumam
Attēli
DWR-921
Back view
View from the right
Pārlādēt
Skatiet arī
