DIR-620A/A1EOL EOS
Wireless N300 Router with 3G/CDMA/LTE Support and USB Port
Apraksts
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
Wireless Interface
Using the DIR-620A device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-620A includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-620A via the user-friendly web-based interface (the interface is available in several languages).
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
Īpašības
Hardware
Interfaces
• 10/100BASE-TX WAN port
• 4 10/100BASE-TX LAN ports
• USB 2.0 port
LEDs
• POWER
• STATUS
• WLAN / WPS
• INTERNET
• 4 LAN LEDs
• USB
Buttons
• POWER button to power on/power off
• RESET button to restore factory default settings
• WPS button to set up secure wireless connection and enable/disable wireless network
Antenna
• Two internal omnidirectional antennas (2dBi gain)
MIMO
• 2 x 2
Power connector
• Power input connector (DC)
Software
WAN connection types
• LTE
• 3G
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IP / Dynamic IP
• Static IPv6 / Dynamic IPv6
• PPPoE + Static IP
• PPPoE + Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• Support of IEEE 802.1X for Internet connection
• DHCP server/relay
• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
• DNS relay
• Dynamic DNS
• Static IP routing
• Static IPv6 routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• WAN reservation
Firewall functions
• IP filter
• IPv6 filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
• IPSec tunnels
USB interface functions
• USB modem
  Auto connection to available type of supported network (4G/3G/2G)1
  Auto configuration of connection upon plugging in USB modem2
  Enabling/disabling PIN code check, changing PIN code3
• USB storage
  File browser
  Print server
  Access to storage via accounts
  Built-in Samba server
  Built-in FTP server
  Built-in DLNA server
  Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management
• Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
• Multilingual web-based interface for configuration and management
• Support of remote logging
• Ping utility
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Managing connected stations
• Advanced settings
Wireless connection rate
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
• 802.11b (typical at room temperature 25 °C)
  17dBm (+/-1.5dB) at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
  17dBm (+/-1.5dB) at 6, 9, 12Mbps
  16dBm (+/-1.5dB) at 18, 24Mbps
  15dBm (+/-1.5dB) at 36, 48, 54Mbps
• 802.11n (typical at room temperature 25 °C)
  HT20/HT40
  16,5dBm (+/-1.5dB) at MCS0/1/2/8/9/10
  16dBm (+/-1.5dB) at MCS3/4/11/12
  15,5dBm (+/-1.5dB) at MCS5/13
  15dBm (+/-1.5dB) at MCS6/14
  14dBm (+/-1.5dB) at MCS7/15
Receiver sensitivity
• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
  -82dBm at 1Mbps
  -80dBm at 2Mbps
  -78dBm at 5.5Mbps
  -76dBm at 11Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
  -85dBm at 6Mbps
  -84dBm at 9Mbps
  -82dBm at 12Mbps
  -80dBm at 18Mbps
  -77dBm at 24Mbps
  -73dBm at 36Mbps
  -69dBm at 48Mbps
  -68dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs))
  HT20
  -82dBm at MCS0/8
  -79dBm at MCS1/9
  -77dBm at MCS2/10
  -74dBm at MCS3/11
  -70dBm at MCS4/12
  -66dBm at MCS5/13
  -65dBm at MCS6/14
  -64dBm at MCS7/15
  HT40
  -79dBm at MCS0/8
  -76dBm at MCS1/9
  -74dBm at MCS2/10
  -71dBm at MCS3/11
  -67dBm at MCS4/12
  -63dBm at MCS5/13
  -62dBm at MCS6/14
  -61dBm at MCS7/15
Modulation schemes
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Physical Parameters
Dimensions
• 134 x 83 x 98 mm (5.3 x 3.3 x 3.9 in)
Weight
• 204 g (0.45 lb)
Operating Environment
Power
• Output: 12V DC, 1A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DIR-620A
• Power adapter DC 12V/1A
• Ethernet cable (CAT 5)
Supported USB modems4
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• D-Link DWR-710
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E352 (Megafon)
• Huawei E367 (3G mode)
• Huawei E392 (3G mode)
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
CDMA
• Airplus MCD-650
• Airplus MCD-800
• AnyDATA ADU-300A
• AnyDATA ADU-500A
• AnyDATA ADU-510A
• Huawei EC306
• ZTE AC5710
• ZTE AC5730
LTE
• Huawei E3131
• Huawei E3272
• Huawei E3351
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-2
• Megafon M100-3
• Megafon M100-4
• Megafon M150-1
• Quanta 1K6E (Билайн 1K6E)
• MTS 824F
• Yota LU-150
• Yota WLTUBA-107
• ZTE MF823
• ZTE MF827
Smartphones in USB tethering mode
• Some models of Android smartphones
1For LTE and GSM USB modems.
2For LTE and GSM USB modems.
3For GSM USB modems only.
4The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Sertifikāti
Informācija pasūtījumam
DIR-620A/A1  Wireless N300 Router with 3G/CDMA/LTE Support and USB Port
Attēli
DIR-620A/A1A1
Back view
Left side view
View from the right
Pārlādēt
Skatiet arī
