Ātrā meklēšana
Produkta iespējas:
Dual-Band Unified Wireless Service Router
Īpašības:
Ethernet Interface
• 2 10/100/1000 Mbps WAN Ports
• 4 10/100/1000 Mbps LAN Port
Wireless Interface
• 802.11 ac/a/b/g/n (Concurrent dual band)
• 3 Detachable 2 dBi Omni-Directional Antennas
USB 2.0
• 2 USB 2.0 ports
Console port
• RJ-45
Performance***
Firewall Throughput****
• 950 Mbps
VPN Throughput*****
• 250 Mbps
Concurrent Sessions
• 100 000
New Sessions (per second)
• 1000
Firewall Policies
• 600
Internet Connection Type
• Static/Dynamic IP
• PPPoE/L2TP/PPTP
• Multiple PPPoE
Firewall System
• Static Route
• Dynamic Route: RIP v1/v2, OSPF, OSPFv3
• Dynamic DNS
• Inter-VLAN Route
• NAT, PAT
• Web Content Filtering: Static URL, Keywords, Dynamic WCF (License is required)
• Intrusion Prevention System (IPS): Signature Package Included in Firmware
• Authentication: Internal User Database, Radius, POP3, LDAP, AD, NT Domain
Networking
• DHCP Server/Client
• DHCP Relay
• IEEE 802.11q VLAN
• VLAN (port-based)
• IP Multicast: IGMP Proxy, IGMP Snooping
• IPv6
• Route Failover
• Outbound Load Balancing
• 3G/4G** Redundancy
Virtual Private Network (VPN)
• VPN Tunnels: 155
• IPSec Tunnels: 70
• PPTP/L2TP Tunnels: 25
• GRE Tunnels: 20
• Encryption Methods: DES, NULL
• IPSec/PPTP/L2TP Server
• IPSec NAT Trraversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
Bandwidth Management
• Maximum Bandwidth Control
• Priority Bandwidth Control:
  - Port-based QoS
  - 3 Classes
System Management
• Web-based User Interface
• Command Line
• SNMP v1, v2c, v3
Wireless
Security
• Wired Equivalent Privacy (WEP)
• Wi-Fi Protected Setup (WPS)
• Wi-Fi Protected Access – Personal (WPA-PSK)
• Wi-Fi Protected Access – Enterprise (WPA-EAP)
• Wi-Fi Protected Access версия 2 – Personal (WPA-PSK)
• Wi-Fi Protected Access версия 2 – Enterprise (WPA-EAP)
• Multiple Service Set Identifier (SSID)
• Service Set Identifier (SSID) to VLAN Mapping
Wireless Frequency
• 802.11b/g/n: 24 GHz to 2.483 GHz
• 802.11a/n/ac: 5.18 GHz to 5.825 GHz
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n (2.4 GHz): 6.5 ~ 300 Mbit/s
• IEEE 802.11n (5 GHz): 6.5 ~ 150 Mbit/s
• IEEE 802.11ac: 7.2 ~ 1300 Mbit/s
Transmitter Output Power******
• IEEE 802.11a:
15 dBm at 6~54 Mbit/s
• IEEE 802.11b:
20 dBm at 1~11 Mbit/s
• IEEE 802.11g:
14 dBm at 6~54 Mbit/s
• IEEE 802.11n:
14 dBm at 6~300 Mbit/s (2.4 GHz)
15 dBm at 6~150 Mbit/s (5 GHz)
• IEEE 802.11ac:
12 dBm at 7.2~1300 Mbit/s
Receiver Sensitivity
• IEEE 802.11a:
-82 dBm at 6 Mbit/s
-81 dBm at 9 Mbit/s
-79 dBm at 12 Mbit/s
-77 dBm at 18 Mbit/s
-74 dBm at 24 Mbit/s
-70 dBm at 36 Mbit/s
-66 dBm at 48 Mbit/s
-65 dBm at 54 Mbit/s
• IEEE 802.11b:
-89 dBm at 2 Mbit/s
-83 dBm at 11 Mbit/s
• IEEE 802.11g:
-82 dBm at 6 Mbit/s
-81 dBm at 9 Mbit/s
• IEEE 802.11n:
2.4 GHz/HT-20:
-82 dBm at MCS0/8/16
-79 dBm at MCS1/9/17
-77 dBm at MCS2/10/18
-74 dBm at MCS3/11/19
-70 dBm at MCS4/12/20
-66 dBm at MCS5/13/21
-65 dBm at MCS6/14/22
-64 dBm at MCS7/15/23
2.4 GHz/HT-40:
-79 dBm at MCS0/8/16
-76 dBm at MCS1/9/17
-74 dBm at MCS2/10/18
-71 dBm at MCS3/11/19
-67 dBm at MCS4/12/20
-63 dBm at MCS5/13/21
-62 dBm at MCS6/14/22
-61 dBm at MCS7/15/23
5 GHz/HT-20:
-82 dBm at MCS0
-79 dBm at MCS1
-77 dBm at MCS2
-74 dBm at MCS3
-70 dBm at MCS4
-66 dBm at MCS5
-65 dBm at MCS6
-64 dBm at MCS7
5 GHz/HT-40:
-79 dBm at MCS0
-76 dBm at MCS1
-74 dBm at MCS2
-71 dBm at MCS3
-67 dBm at MCS4
-63 dBm at MCS5
-62 dBm at MCS6
-61 dBm at MCS7
• IEEE 802.11ac:
VHT-20:
-82 dBm at MCS0
-79 dBm at MCS1
-77 dBm at MCS2
-74 dBm at MCS3
-70 dBm at MCS4
-66 dBm at MCS5
-65 dBm at MCS6
-64 dBm at MCS7
-59 dBm at MCS8
-57 dBm at MCS9
VHT-40:
-79 dBm at MCS0
-76 dBm at MCS1
-74 dBm at MCS2
-71 dBm at MCS3
-67 dBm at MCS4
-63 dBm at MCS5
-62 dBm at MCS6
-61 dBm at MCS7
-56 dBm at MCS8
-54 dBm at MCS9
VHT-80:
-76 dBm at MCS0
-73 dBm at MCS1
-71 dBm at MCS2
-68 dBm at MCS3
-64 dBm at MCS4
-60 dBm at MCS5
-59 dBm at MCS6
-58 dBm at MCS7
-53 dBm at MCS8
-51 dBm at MCS9
Physical Parameters
Power Supply
• External Power Supply Unit: DC 12 V/3 A
Max. Power Consumption
• 23.1 W
MTBF
• 360 000 hours
Dimensions
• 180 x 280 x 44 mm
Weight
• 1.728 kg with 3 antennas
Temperature
• Operating: 0 to 40В°C
• Storage: -20 to 70В°C
Humidity
• Operating: 5% to 95% non-condensing
Certifications
EMI
• FCC Class B
• CE Class B
• RCM
• IC
• VCCI
Safety
• cUL
• LVD (EN60950-1)
3rd Party Certification
• IPv6 Ready
• Wi-Fi
• VPNC Basic Interop
* The following portable modem are supported: DWM-152 A1/A2/A3, DWM-156 A1/A2/A3/A5/A6/A7, DWM-157 A1/B1, DWM-158 D1, DWP-156 A1/B1, DWP-157 A1/B1, Huawei E1550, E173, E303 and EC306.
** Available with future firmware upgrade.
*** Firewall throughput is measured using UDP traffic with a 1518 bytes packet size, adhering to RFC2544.
**** Actual performance may vary depending on network conditions and activated services.
***** VPN throughput is measured using UDP traffic with the packet size 1420 bytes and encryption method 3DES plus SHA-1, adhering to PFC2544.
****** Maximum power output varies in each country depending on local power regulations.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
