DGS-3204EOL EOS
24 10/100/1000BASE-T ports, 4 combo SFP, redundant power support
Description
The DGS-3024, an all-Gigabit Layer 2 switch designed for departmental connection, provides 24 10/100/1000BASE-T ports for copper Gigabit connection, plus 4 combo SFP for flexible fiber backbone attachment. Powerful yet affordable, this switch brings the Gigabit speed to the desktops and servers, while providing all the necessary functions such as port trunking, VLAN, priority queues and redundant power supply to allow a department to effectively deploy a bottleneck-free switching network for easy integration with a larger enterprise or campus network.
24 Copper Gigabit Connections
4 Combo SFP for Flexible Fiber Connection Security & Quality of Service Support With 24 10/100/1000BASE-T auto-sensing ports in a lowprofile device, this switch is a cost-effective solution for Gigabit networking. All ports support auto MDI/MDIX, allowing you to connect to workstations and servers from any port without the need to change your usual twisted-pair network cables.
4 combo SFP are provided for flexible fiber connection
You can select to install optional transceiver modules in these slots for short, medium or long-distance fiber backbone attachment. Use of the SFP will disable their corresponding built-in 10/100/1000BASE-T connections. Designed as a cost-effective managed switch for departmental connection, the DGS-3024 gives you all the basic security and Quality of Service (QoS) functions including 802.1Q VLAN, GVRP, 802.1p Priority Queues, 802.1x access control, and broadcast storm control. These features facilitate the deployment of office applications such as VoIP Internet telephone and streaming media.
Port Trunk & Redundancy Support
The DGS-3024 supports 802.3ad Link Aggregation*, allowing you to combine multiple ports into a multi-link for higher bandwidth connections to servers or the network backbone. For redundancy, the switch supports 802.1 Spanning Tree for backup bridge paths, and can be connected to an external power supply to maximize network uptime. In case the built-in internal power supply fails, the redundant power supply unit will automatically provide the required power to ensure continuous operation.
Network Management
The DGS-3024 addresses today's diverse business and IT requirements through its robust support of standards based network management protocols (SNMP/RMON/BOOTP/Telnet/Web) and port mirroring. It can be easily integrated with most third-party network management products.
General features
Device Ports
- 24 10/100/1000BASE-T ports
- 4 SFP
- RS-232 console port
Standard Support
- IEEE 802.3 10BASE-T/802.3u 100BASE-TX/802.3ab 1000BASE-T
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
- Auto MDI/MDIX
- Port mirroring
Mini GBIC (SFP) Support
- IEEE 802.3z 1000BASE-LX (DEM-310GT transceiver)
- IEEE 802.3z 1000BASE-SX (DEM-311GT transceiver)
- IEEE 802.3z 1000BASE-LH (DEM-314GT transceiver)
- IEEE 802.3z 1000BASE-ZX (DEM-315GT transceiver)
Switch Fabric
35.7Mpps (48Gbps)
Diagnostic LEDs
Per device:
- Power
- Console
- RPS
Per RJ-45 port:
- Speed
- Link/Act
Per SFP port:
- Link/Act
Software
VLAN
- IEEE 802.1Q Tagged VLAN
- GVRP
- Max. number of VLANs: 255 static, 64 dynamic
Priority Queues (CoS)
- Standard: IEEE 802.1p
- Max. number of queues: 4 per port
Network Access Security
- SSL
- SSH
- RADIUS
- TACACS+
- 802.1x Port-based access control
Spanning Tree
- 802.1D Spanning Tree
- 802.1w Rapid Spanning Tree
- 802.1s Multiple Spanning Tree
Performance
Transmission Method
Store-and-forward
MAC Address Table
8K entries per device
MAC Address Learning
- Dynamic entries: automatic update
- Static entries: user-defined
Packet Filtering/Forwarding Rates (half duplex)
1,488,100 pps per port (max.)
RAM Buffer
512KB per device
Jumbo Frame Size
9216bytes (max.)
Broadcast Storm Control
Rate control of Broadcast, unknown Multicast and Unicast packets
Management Support
- SNMP v.1, v.2c, v.3
- Web-based management
- CLI (command line interface)
- RMON monitoring
- SNTP
- SYSLOG
- Web GUI traffic monitoring
- DHCP/Bootp client
- SNMP trap on MAC notification
- Telnet server
MIBs
- MIB-II (RFC 1213)
- Bridge MIB (RFC 1493)
- RMON MIB (RFC 1757)
- 802.1Q VLAN/802.1p MIB (RFC 2674)
- IF MIB (RFC 2233)
- Ethernet-like MIB (RFC 1643)
- D-Link enterprise MIB
RMON Groups
1, 2, 3, 9 (Alarm, Statistics, History, Event)
IP Number Self-identification
Through DHCP client, Bootp client
Firmware Upgrade
TFTP
Console Port
DB-9 RS-232 DCE
Certificates
Order info
DGS-3204  24 10/100/1000BASE-T ports, 4 combo SFP, redundant power support
Pictures
DGS-3204
Front view
Back view
Downloads
Support Resources
