Quick find
Product features:
Broadband Router
EOL EOS
Description:
High performance
D-Link DIR-100 Broadband Router is designed for sharing a broadband Internet connection through a DSL or cable modem by a group of users. Easy to install and operate, this router is ideal for novice users, which create their first networks at home and in small offices.
Quality of Service (QoS)
DIR-100 provides prioritized transmission and reception of VoIP and online traffic to/from the Internet, providing a group of users with reliable network connection with no traffic delays. QoS support provides broadband access for applications such as Internet telephony, multimedia and games on the Internet.
The high level of network security
Router DIR-100 is equipped with a firewall to protect the computers on the network from DOS attacks and virus attacks. With packet filtering the device provides port-based and source/destination MAC/IP-based access control. Using port forwarding feature the router can be configured to allow separate FTP, and game servers to share the same Internet visible IP address, and at the same time, servers and workstations will remain protected from hackers. Users can set up a home or office Web-site by configuring any of the built-in LAN ports to work as a port DMZ. The parental control feature allows parents and network administrators to filter out unwanted URL addresses of Web sites, block domains and control the time of the Internet operation via a schedule.
Products | Support  | News  | About |
