DGS-1016D/F1EOL EOS
16-Port 10/100 Switch
Description
Think Green
D-Link’s DGS-1016D 16-Port Gigabit Switch is part of a new series of SOHO/SMB devices that make use of D-Link’s Green Ethernet technology, featuring IEEE 802.3az EEE and EEE+ modes to provide more energy savings and a longer product life without sacrificing operational performance or functionality. IEEE 802.3az EEE is a power-saving feature that reduces energy use when the switch is at low utilization. EEE+ is a power-saving feature that is similar to IEEE 802.3az EEE. However, unlike EEE, EEE+ can function regardless of whether the switch’s link partner is EEE-compliant or not. Recyclable packaging and minimized use of harmful substances (RoHS compliant) make this switch truly environmentally friendly.
Conserves Energy
By building on the foundation of D-Link’s Green Ethernet technology, the 16-Port Gigabit Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjusts power usage accordingly, helping you save energy without affecting networking performance. This helps you reduce your power usage and your energy bill.
Environmentally Friendly
The 16-Port Gigabit Switch was designed with the environment in mind, and was built to follow RoHS standards to minimize the use of hazardous materials. It uses recyclable packaging that helps reduce waste, and complies with the WEEE directive.
General features
Key features
• D-Link Green Technology
• Power saving by cable length detection and link status
• Inexpensive Gigabit solution for SOHO/SMB
• Silent, fanless design
• Auto MDI/MDI-X crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Supports 9,600 Bytes Jumbo Frames
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Supports Cable Diagnostics Function
• Supports D-Link’s unique EEE+ mode
• RoHS compliant
• Plug-and-play installation
Number of ports
• 16 Gigabit ports
Switching fabric
• 32Gbps
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.1p QoS (4 queues, strict mode)
• IEEE 802.3az EEE
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Gigabit Ethernet:
• 2000Mbps (full duplex)
Topology
• Star
Network cables
10BASE-T:
• UTP CAT 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX, 1000BASE-T:
• UTP CAT 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
LED indicators
• Per port: Link/Activity/Speed
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 8K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates (half duplex)
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
• Gigabit Ethernet: 1,488,000pps per port
RAM buffer
• 512KB per device
Certificates
Order info
DGS-1016D/F1 16-Port 10/100 Switch
Pictures
DGS-1016D/F1/F1
Front view
Back view
Downloads
Support Resources
