Quick find
Product features:
100Base-FX Multi-Mode SFP transceiver (up to 2 km)
Description:
div>
The DEM-211/DD Gigabit SFP fiber transceiver is external transceiver designed for insertion in SFP (Small Form-Factor Pluggable) slot of network device for transmission and reception of data signals on the fiber cables. The transceivers provides IEEE 802.3u compliant link for up to 100 Mbps in the half duplex mode (or 200 Mbps full-duplex mode) transmission to deliver the speed, reliable long-distance (up to 2 km) data transfer.
The DEM-211/DD transceiver uses standard duplex LC connector for fiber cable connection. It conforms to industry standards. Hot-swap capability allows network administrators to plug or unplug it from the SFP slot without having to turn off the power of the connected device.
Products | Support  | News  | About |
