DFE-904EOL EOS
Ethernet/Fast Ethernet Dual-Speed Hub
Description
The D-Link DFE-904 dual-speed Ethernet/Fast Ethernet hub is designed to allow easy migration and integration between 10-Mbps Ethernet and 100-Mbps Fast Ethernet.
The DFE-904 hub can operate with either IEEE 802.3 10BASE-T connections (twisted-pair Ethernet operating at 10 megabits per second), or IEEE 802.3u 100BASE-TX connections (twisted-pair Fast Ethernet operating at 100  megabits per second).
General features
Standards
IEEE 802.3 10BASE-T Ethernet repeater, IEEE 802.3u 100BASE-TX Fast Ethernet repeater (Class II)
Data Transfer Rate
Ethernet—10 Mbps; Fast Ethernet—100 Mbps.
Power Supply
External power supply with 9V DC/1A output
Power Consumption
4W
Dimensions (W × D × H)
110 × 75 × 29 mm
Weight
500 g
Operating Temperature
-10° to 55° C
Storage Temperature
-25° to 55° C
Humidity
5% to 95%, non-condensing
Emissions
FCC Class A, CE , VCCI Class A, C-Tick
Safety
UL, CSA
Certificates
Order info
DFE-904  Ethernet/Fast Ethernet Dual-Speed Hub
Pictures
DFE-904
Front view
Downloads
Support Resources
