Quick find
Product features:
24-Port 10/100/1000 Switch + 4 combo SFP ports
EOL
Description:
D-Link’s DGS-3224TGR is a high performance managed Layer 2 Gigabit switch that provides an ideal solution for Enterprise Gigabit applications. With (24) 10/100/1000Mbps Gigabit Ethernet ports with (4) combo SFP slots, the DGS-3224TGR is designed to meet the needs of the most demanding departmental and Enterprise connectivity applications.
High Performance Wire-Speed Architecture
The DGS-3224TGR supports full duplex wire-speed forwarding, 16,000 MAC addresses and the ability to classify and mark traffic based on 802.1p, DiffServ, ToS, MAC Address, IP Address and/or TCP/ UDP Port Numbers into (8) priority queues. The DGS-3224TGR can be used as a cost-effective Gigabit wiring closet solution or a high performance backbone aggregation device.
Network Management
D-Link’s DGS-3224TGR addresses today’s diverse business and IT requirements through its robust support of standards based network management protocols (SNMP/RMON/BOOTP/Telnet/Web) and port mirroring. By supporting standards-based network management protocols, the DGS- 3224TGR can be easily integrated with most third-party network management products.
Advanced Enterprise Features
The DGS-3224TGR brings advanced Enterprise functions to a new level of affordability without compromising advanced features including: QoS/CoS, Multicast, VLANs, Port Trunking Port Mirroring, Rapid Spanning Tree, Security, and Network Management. These features facilitate the deployment of applications across an Enterprise, including: VOIP, streaming media, and multicast content delivery (IP video, software deployment…etc).
Investment Protection
With support for up to (4) GBIC modules, the DGS-3224TGR can easily adapt to changes in customer media requirements without the need to perform an expensive “forklift” upgrade. By supporting SFP mini/GBIC modules, customers can migrate to more advanced solutions in the future, while still protecting a portion of their original investment.
Products | Support  | News  | About |
