Quick find
Product features:
10GBASE-ER 10Gigabit Ethernet XFP Optical Transceiver, 40km
Description:
Optical Data Communication
This transceiver provides a high performance and cost-effective solution for serial optical data communication applications specified for multi-mode supporting up to 10.7Gbps rate. It operates with +3.3V and +5V power supply. The transceiver is intended for multi-mode fiber, operates at a nominal wavelength of 1310nm and complies with Multi-Source Agreement (MSA) Small Form Factor Pluggable (XFP). The transceiver consists of a transmitter optical subassembly, a receiver optical subassembly and an electrical subassembly. It is housed in a metal package and the combination produces a reliable component.
Wide Ranging Applications
This fiber Gigabit transceiver is ideal for deployment as for Ethernet links, fiber channel links at 10Gbps, high-speed backbone interconnection and switched backbones.
Products | Support  | News  | About
