DPH-150S/RUEOL EOS
BROADBAND INTERNET IP PHONE
Description
INTERNET PHONE MADE FOR HOME & OFFICE
The DPH-150S Broadband Internet IP Phone allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network (VoIP) technology with advanced communication features, and is compatible with industry-wide phone services. This sleek designed IP phone gives you the advantages of VoIP, while retaining the same look and feel of a traditional desktop telephone.
SUPERIOR VOICE QUALITY
The DPH-150S IP phone incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference and speed dialing to make it convenient to dial out or answer phone calls.
SURF INTERNET WHILE MAKING INTERNET PHONE CALLS
The DPH-150S comes with two Ethernet ports, one to connect to a DSL or cable modem, or to your broadband router. In an offce environment equipped, this port can also connect to a PoE switch and obtain power directly from the network, dispensing you of the need to hook the IP phone to an AC power outlet. Once connected and logged onto the Internet, you are ready to make and receive calls. In addition, this IP phone provides another Ethernet port for connection to your PC, so you can talk on the IP telephone while browsing web sites, send e-mail, transfer fles and do other network tasks on your PC.
QUALITY OF SERVICE AND SECURITY
The DPH-150S supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides priority queues to streamline traffc so web browsing and Internet download will not interfere with voice traffc and degrade Internet phone quality.
General features
Certificates
Order info
Pictures
DPH-150S/RU
Front view
Back view
Downloads
Support Resources
