DCS-2121EOL EOS
3GPP Megapixel Camera with 16x Digital Zoom
Description
PRODUCT DESCRIPTION
The DCS-2102/2121 is a versatile and unique surveillance solution for your small offce or home.  Unlike a standard webcam, the DCS-2102/2121 is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance.  The DCS-2102/2121 can be accessed remotely and controlled from any PC or notebook over the local network or through the Internet via a web browser.  The simple installation and intuitive web-based interface offer easy integration with your Ethernet/Fast Ethernet or 802.11g wireless network.  The DCS-2102/2121 also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
WIRELESS G CONNECTIVITY
The DCS-2121 offers both 802.11g wireless and Ethernet/Fast Ethernet connectivity, making the DCS-2121 easy to integrate into your existing network environment.  The DCS-2121 works with a 10Mbps Ethernet based network or 100Mbps Fast Ethernet based network for traditional wired environments and works with 802.11g routers or access points for added fexibility.  The Site Survey feature also allows you to view and connect to nearby wireless networks.
SNAPSHOTS, RECORDING & STORAGE
Using the Snapshot and recording features, you can save snapshots and record video and audio directly from the web browser to a local hard drive without installing any software, making it convenient to instantly capture any moment from a remote location.  The DCS-2102/2121 allows you to record directly to a local network area storage device without the use of a dedicated PC for storing recorded video.
General features
OS SUPPORT
Device
+   Windows 2000 / Windows XP /Windows Vista / 3GPP
Utility
+   Windows 2000 / Windows XP / Windows Vista
NETWORKING PROTOCOL
+ IPV4, ARP, TCP, UDP, ICMP
+ DHCP Client  + NTP Client
+ DNS Client  + DDNS Client
+ SMTP Client  + FTP Client
+ HTTP Server  + Samba Client
+ PPPoE  + RTP
+ RTSP  + RTCP
+ 3GPP
LAN
+ 10/100BASE-TX port
+ IEEE 802.3 compliant
+ IEEE 802.3u compliant
+ Supports Full-Duplex operation
+ MDI/MDIX auto-negotiation
+ 802.3x Flow Control support for Full-Duplex mode
WIRELESS CONNECTIVITY
802.11b/g Wireless with WEP/WPA/WPA2 Security
WIRELESS TRANSMIT OUTPUT POWER
16dbm for 11b, 12dbm for 11g (typical)
WIRELESS RECEIVER  SENSITIVITY
  (11g Packet Error Rate < 10%)
+  54Mbps: <-66dbm
  (11b Packet Error Rate <8%)
+  11Mbps: < -82dbm
VIDEO CODEC
MPEG-4/MJPEG
AUDIO CODEC
+ GSM-AMR: 8kbps,
+ ADPCM: 8Kbps
SENSOR
¼ inch color 1.3MP CMOS Sensor
SDRAM
64 Mbytes
FLASH MEMORY
8 Mbytes
SD-CARD SLOT
Supports up to 16GB
LENS
Focal Length: 5.01mm, F2.8
MIC
50dB +/- 3dB, Omni-directional
I/O CONNECTORS
+ 1 Input (photo relay, active high 12V, +/-3V, dropout: 0 VDC)
+ 1 Output (photo relay, Close circuit current: AC 70mA or DC 100mA; 40Ohm; Open circuit voltage: 240 VAC or 350VDC)
AUDIO OUT
Yes
RESET BUTTON
Reset to factory default
VIDEO ALGORITHM SUPPORTED
+ MPEG-4/MJPEG simultaneous dualformat compression
+ JPEG for still image
VIDEO FEATURES
+ Adjustable image size and quality
+ Time stamp and text overlay
+ Flip and Mirror
VIDEO RESOLUTION
Sensor Output Modes:
VGA (640 X 480)
+  640 x 480 at 30fps
+  320 x 240 at 30fps
+  160 x 120 at 30fps
XGA (1024 X 768)
+  1024 x 768 at 10fps
+  512 x 384 at 10fps
+  256 x 192 at 10fps
SXGA (1280 x 1024)
+  1280 x 1024 at 10fps
LUX
0.5 lux@F2.8
3A CONTROL
+ AGC (Auto Gain Control)
+ AWB ( Auto White Balance)
+ AES (Auto Electronic Shutter)
FREQUENCY
50~16000Hz
SIGNAL/NOISE RATIO
Certificates
Order info
DCS-2121   Megapixel 802.11g Wireless Internet Camera
Pictures
DCS-2121
Front view
Back view
Downloads
Support Resources
