DCS-20EOL EOS
Description
D-Link’s SecuriCam IP Camera accessories provide cost-effective solutions for the diversity of application. The DCS-10 IR illuminator and DCS-20 IR lens can be used for both day and night surveillance, and the DCS-25 vari-focal CS lens provides easy installation without the need to change lenses for particular applications. Protect your home and business by maximizing the full potential of D-Link’s IP cameras and these benefcial accessories.
The DCS-20 is a CS mount IR fxed lens for 1/3” and 1/4” sensors.
General features
Supported Devices
- DCS-3410
- DCS-3420
Dimensions
58.6 (Ø) x 24 (D) mm (2.3 x 0.95 inches)
Weight
90 g (0.20 lbs)
Distance
10 m
Focal Length
F6.0 mm / F2.0
Power On
Auto-control under 10 lux
Power Consumption
160mA (max.)
