Product features:
AirPremier® N PoE Access Point with Plenum-rated Chassis EOL EOS |
General features:
Standards
IEEE 802.11n
IEEE 802.11g
IEEE 802.3ab
IEEE 802.3af
IEEE 802.3u
IEEE 802.3
Network Management
Telnet - Secure (SSH) Telnet
Web Browser Interface
HTTP - Secure HTTP (HTTPS)
SNMP Support
D-View Module - Private MIB
AP Manager II
AP Array
Security
WPA™-Personal
WPA-Enterprise
WPA2™-Personal
WPA2-Enterprise
64/128-bit WEP
SSID Broadcast Disable
MAC Address Access Control
Rogue AP Detection
VLAN/SSID Support
802.1q/Multiple SSID support up to 8
Quality of Service (QoS)
4 Priority Queues
WMM Wireless Priority
Wireless Frequency Range
2.4 GHz to 2.4835 GHz
Operating Modes
Access Point (AP)
WDS with AP
WDS/Bridge (No AP Broadcast)
Wireless Client
Dipole Antenna Gain
5 dBi @ 2.4 GHz
Maximum Transmit Output Power
26 dBm @ 2.4 GHz
LEDs
Power
LAN
2.4 GHz
Maximum Power Consumption
9 Watts with PoE
8 Watts without PoE
Operating Voltage
48 V DC +/- 10 % for PoE or 5 V/2.5 A
Temperature
Operating: 32°F to 104°F (0°C to 40°C)
Storing: -4°F to 149°F (-20°C to 65°C)
Humidity
Operating: 10% ~ 90% (Non-condensing)
Storing: 5% ~ 95% (Non-condensing)
Certifications
FCC Class B
UL 2043
IC
Wi-Fi®
Weight
768 g
Dimensions
166 mm x 188 mm x 37 mm
1 This unit is designed for indoor environments, you might violate local regulatory requirements by setting up this unit in outdoor environments.
2 Maximum wireless signal rate derived from IEEE Standard 802.11g, and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Support Resources
