Quick find
Product features:
Wireless N300 Dual Band USB Adapter
Description:
Wireless dual-band (2.4/5GHz) wireless USB adapter DWA-160 provides a reliable wireless connection to a public wireless network ("hotspot") or dual band router, which can be used for streaming the high-definition video (HD). DWA-160 enables you to connect your computer to a high-speed wireless network and provides excellent signal reception. Once connected, you can get access to high-speed Internet connection, as well as the total secure access to your photos, files, music, video, printers, and storage.
Use two frequency bands
DWA-160 supports dual band technology: check your email and surf the Internet on the 2.4GHz band, and stream HD video and other media content using the 5GHz band.
Increased speed and expanded network range
DWA-160 Xtreme N dual band USB adapter provides a connection to the wireless network at a faster speed and at a greater distance than the previous 802.11 standards adapters. This ensures quick and reliable connection anywhere in your home.
Easy installation and use
Installation Wizard provides step-by-step instructions that you can use to quickly and easily connect to a wireless network, even in the absence of experience with networks. Due to its high performance, reception and security, this adapter is the best choice for wireless connection of desktop computers.
Products | Support  | News  | About |
