Quick find
Product features:
Wireless N300 Access Point & Router
EOL EOS
General features:
Hardware
WAN Interface
• 1 10/100BASE-TX Ethernet port for cable or DSL modem or private Ethernet line
LAN Interface
WLAN Interface
• IEEE 802.11n (up to 300Mbps)
• IEEE 802.11b/g
Antenna
• Two 5dBi detachable omnidirectional antennas
• RP-SMA connector
Frequency Range
• 802.11b
2400 ~ 2497MHz ISM band
• 802.11g
2400 ~ 2483.5MHz ISM band
• 802.11n
Data Rate
• 802.11b
11, 5.5, 2, and 1Mbps
• 802.11g
54, 48, 36, 24, 18, 12, 9, and 6Mbps
• 802.11n
MCS
GI3=800ns
GI=400ns
20MHz (Mbps)
40MHz (Mbps)
20MHz (Mbps)
40MHz (Mbps)
0
6,5
13,5
7,2
15
1
13
27
14,4
30
2
19,5
40,5
21,7
45
3
26
54
28,9
60
4
39
81
43,3
90
5
52
108
57,8
120
6
58,5
121,5
65
135
7
65
135
72,2
150
8
13
27
14,4
30
9
26
54
28,9
60
10
39
81
43,3
90
11
52
108
57,8
120
12
78
162
86,7
180
13
104
216
115,6
240
14
117
243
130
270
15
130
270
144,4
300
Modulation Schemes
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Transmitter Output Power
• 802.11b (typical at room temperature 25 °C)
17dBm (±1.5dB) at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
17dBm (±1.5dB) at 6Mbps
17dBm (±1.5dB) at 9Mbps
17dBm (±1.5dB) at 12Mbps
16dBm (±1.5dB) at 18Mbps
16dBm (±1.5dB) at 24Mbps
15dBm (±1.5dB) at 36Mbps
15dBm (±1.5dB) at 48Mbps
15dBm (±1.5dB) at 54Mbps
• 802.11n (typical at room temperature 25 °C)
HT-20
HT-40
16.5dBm (±1.5dB) at MCS0/8
16.5dBm (±1.5dB) at MCS1/9
16.5dBm (±1.5dB) at MCS2/10
16dBm (±1.5dB) at MCS3/11
16dBm (±1.5dB) at MCS4/12
15.5dBm (±1.5dB) at MCS5/13
15dBm (±1.5dB) at MCS6/14
14dBm (±1.5dB) at MCS7/15
Receiver Sensitivity
• 802.11b (typical at PER = 8% (1000-byte PDUs))
-82dBm at 1Mbps
-80dBm at 2Mbps
-78dBm at 5.5Mbps
-76dBm at 11Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs))
-85dBm at 6Mbps
-84dBm at 9Mbps
-82dBm at 12Mbps
-80dBm at 18Mbps
-77dBm at 24Mbps
-73dBm at 36Mbps
-69dBm at 48Mbps
-68dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs))
HT-20
HT-40
-82dBm at MCS0/8
-79dBm at MCS0/8
-79dBm at MCS1/9
-76dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS2/10
-74dBm at MCS3/11
-71dBm at MCS3/11
-70dBm at MCS4/12
-67dBm at MCS4/12
-66dBm at MCS5/13
-63dBm at MCS5/13
-65dBm at MCS6/14
-62dBm at MCS6/14
-64dBm at MCS7/15
-61dBm at MCS7/15
Software
Operation Modes
• Access point mode
• Router mode
Network Functions
• WAN connection types
PPPoE
Static IP
Dynamic IP
Static IP + PPPoE
Dynamic IP + PPPoE
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
• DHCP server/relay
• DNS relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIP
• Support of UPnP IGD
• WAN ping respond
• Support of SIP
• Support of RTSP
• PPPoE pass through
Wireless Connection
• Supported security settings
WEP
WPA/WPA2 Personal
WPA/WPA2 Enterprise
• MAC filter
• Managing connected stations
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
• Advanced settings
• WDS
• “Client” function (access point mode)
Wireless network client
Wireless network repeater
• “Client” function (router mode)
WISP repeater
Firewall Functions
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
Configuration and Management
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote logging
• Ping function
• Traceroute utility
Physical and Environmental
LEDs
• Power
• WLAN
• WPS
• LAN
• Internet
Power
• External power adapter DC 12V/0.5А
Buttons
• Power on/off button
• WPS/RESET button
Operating Temperature
• From 0 to 40 C (from 32 to 104 F)
Storage Temperature
• From -20 to 65 С (from -4 to 149 F)
Operating Humidity
• From 10% to 90% non-condensing
Storage Humidity
• From 5% to 95% non-condensing
Products | Support  | News  | About |
