Quick find
Product features:
16-Port 10/100 with 8 PoE 802.3af ports Switch
General features:
Port Standards & Functions
- IEEE 802.3af Power over Ethernet (PoE)
- IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
- IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
- Port mirroring
Number of Ports
16 10BASE-T/100BASE-TX ports (8 PoE ports, 8 non-PoE ports)
Data Transfer Rates
- Ethernet:
10Mbps (half duplex)
20Mbps (full duplex)
- Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
Network Cables
- UTP Cat. 5, Cat. 5e (100 m max.)
- EIA/TIA-568 100-ohm STP (100 m max.)
Media Interface Exchange
Auto MDI/MDIX adjustment for all ports
LED Indicators
- Power (per device)
- CPU (per device)
- Link/Act, Speed (per port)
- 100Mbps (per port)
- PoE (per PoE port)
PoE Ports
Port 1 to Port 8
Power Supplied
Up to 15.4 watts per port
Automatic recognition of connected Powered Device (PD) and sending
power to PD
Automatically disables the port in case port current is over 350mA
Active Circuit Protection
Automatically disables the port in case of is a short
PoE Pinouts
Pins 1, 2, 3, and 6 of Cat. 5 cable
Standard: IEEE 802.1Q
- Maximum number of VLAN: 64 per device
- Supports up to 512 VIDs
Quality of Service (QoS)
- Standard: IEEE 802.1p
- Maximum number of queues: 2
- Port-based
Port Trunks
- Standard: IEEE 802.3ad
- Max. 4 ports per trunk
- 1 port trunk per device
Configuration/Management Methods
- Web-based configuration
- Windows-based utility
- Configuration reset through software or hardware (reset button)
Configuration/Management Functions
- Port speed/full/half duplex setting
- Port power setting
- Switch auto-discovery
Switch Fabric
Transmission Method
MAC Address Table
4K entries per device
MAC Address Learning
Automatic update
Packet Filtering/Forwarding Rates (half duplex)
Maximum 1,488,095 pps per port
RAM Buffer
512KB per device
Physical & Environmental
AC Input
100 to 240 VAC 50/60Hz internal universal power supply
Power Consumption
- Maximum 9 watts per device (without any PoE devices connected)
- Maximum 130 watts per device (when all 8 PoE devices are connected)
440 (W) x 140 (D) x 44 (H) mm
19-inch standard rack mount width, 1 U height
2.15 kg
Operating Temperature
0o to 40oC
Storage Temperature
-10o to 70 oC
Operating Humidity
10% to 90% RH
Storage Humidity
5% to 90% RH
Emission (EMI)
- FCC Class A
- CE Class A
- VCCI Class A
- UL
Products | Support  | News  | About |
