Quick find
Product features:
ADSL Router
General features:
Router
Interface
- 1 RJ-11 ADSL port
- 4 RJ-45 10/100BASE-TX Fast Ethernet LAN switch ports with auto MDI/MDIX
Routed Packet Type
IP packets
Routing Protocols & Methods
- RIP v1/v2 and static routing
- Dynamic routing
DHCP Support
- DHCP server (for automatic IP assignment)
- DHCP Client
Security
- VPN support: PPTP/L2TP/IPSec pass-through
- Network Address/Port translation (NAPT)
- Authentication: PAP and CHAP
- DoS (UDP/TCP), detection of known attacks
- SPI firewall protection
- Web login password authentication
Configuration & Network Management
- HTTP server for web-based management
- Remote management through Telnet or HTTP
- System logs
- Support UPnP 1.0
- Configuration backup and restore
- Factory reset
Statistics Monitoring
Ethernet, ATM and ADSL statistics
Diagnostic LEDs
- Power
- Status (system)
- ADSL Link/Act
- Ethernet Link/Act
Built-in ADSL Modem
WAN ADSL Line Interface
ADSL standards: ANSI T1.413 Issue 2, ITU G.992.1 (G.dmt) Annex B, ITU G.992.2 (G.lite) Annex B, ITU G.994.1 (G.hs)
Data Rate (ADSL Standard)
- T1.413/G.dmt, downstream: up to 8Mbps, upstream: up to 1Mbps
- G.lite, downstream: up to 1.5Mbps, upstream: up to 512 Kbps
Performance
Passed U-R2 Performance Criteria
ATM/ADSL
- ATM signaling: UNI3.0, 3.1 and 4.0
- ATM traffic shaping: UBR, CBR, VBR
Bridged/PPP Support
- Bridged Ethernet over ATM
- Classical IP over ATM
- PPP over ATM
- PPP over Ethernet
Physical & Enviromental
Power Input
Through 12VAC 1.2A external power adapter
Dimensions
180 x 141 x 30 mm (device only)
Weight
332 grams (device only)
Operating Temperature
0 to 40 C
Storage Temperature
-20 to 70 C
Operating Humidity
5% to 95% non-condensing
Emission (EMC/EMI)
CE Class B
Safety
CSA International (CSA 950, EN 60950, IEC 60950, UL 1950)
Products | Support  | News  | About
