MINIMUM SYSTEM REQUIREMENTS
+ Cable or DSL Modem with Ethernet Port
+ Computer with Windows XP SP2 or Windows 2000 SP4 or Mac OS X (v10.4/v10.3) or Linux-Based Operating System and an Installed Ethernet Adapter
+ Internet Explorer 6 or Firefox 1.5 or Later
STANDARDS
+ IEEE 802.11g
+ IEEE 802.11b
+ IEEE 802.3
+ IEEE 802.3u
WIRELESS SIGNAL RATES1 WITH AUTOMATIC FALLBACK
+ 54, 48, 36, 24, 18, 12, 11, 9, 6, 5.5, 2, & 1Mbps
WIRELESS FREQUENCY RANGE
+ 2.4GHz to 2.462GHz
MODULATION TECHNOLGOY
+ Orthogonal Frequency Division
Multiplexing (OFDM)
+ Complementary Code Keying (CCK)
WIRELESS TRANSMIT POWER
+ 15dBm +/- 2dBm
ANTENNA
+ Detachable Dipole Antenna (Reverse SMA Plug)
SECURITY
+ WEP 64/128-Bit Data Encryption (User-Selectable)
+ Wi-Fi Protected Access (WPA/WPA2)
ADVANCED FIREWALL FEATURES
+ Network Address Translation (NAT)
+ Stateful Packet Inspection (SPI)
+ MAC Filtering
+ Website URL Filtering
DEVICE MANAGEMENT
+ Internet Explorer v6 or later; or Firefox 1.5 or Later
Physical & EnviromentalDIAGNOSTIC LED
+ Power
+ Status
+ Internet
+ WLAN (Wireless Connection)
+ LAN
POWER INPUT
+ 5VDC, 1.2A, Through External Power Adapter
DIMENSIONS
+ 112.6 x 147.5 x 31.8 mm
WEIGHT
+ 246 grams (0.5 lb)
CERTIFICATION
+ CE
+ FCC
OPERATING TEMPERATURE
+ 0˚ to 55˚ C (32˚ to 131˚ F)
OPERATING HUMIDITY
+ 95% maximum
1. Maximum wireless signal rate based on IEEE standard 802.11g specifcations. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead lower actual data throughput rate and adversely affect the range.
