DVG-5112SEOL EOS
2-port VoIP telephone adapter
Description
INTERNET PHONE MADE FOR HOME & SOHO
The D-Link DVG-5112S 2-port VoIP Telephone Adapter (TA) allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over IP network technology with advanced communication features, and is compatible with industry wise phone service. With two FSX phone port, this VoIP TA connects you to two ordinary phone set to let you make Internet phone calls.
SUPERIOR VOICE QUALITY
The DVG-5112S incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
SHARE INTERNET ACCESS
The DVG-5112S integrates a router function into the same box, so you can surf web pages, watch video or play on-line games while making Internet phone calls. You do this by connecting your PC to the LAN of this VoIP TA, or by connecting multiple computers to this LAN port through an Ethernet switch. This device provides priority queues to streamline traffic to let you experience superior video and on-line games.
COMPLETE SECURITY
The DVG-5112S supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides NAT firewall to protect your network from Internet intruders. For access control, it filters users’ packets with port-based and IP-based filters. Parental control allows you to block undesired web sites and set time schedule for Internet logins.
General features
DEVICE INTERFACES
+ 2 RJ-11 FXS phone port
+ 1 RJ-45 10/100BASE-TX WAN port with auto-MDI/MDIX
+ 1 RJ-45 10/100BASE-TX LAN port with auto-MDI/MDIX
GENERAL FEATURES
+ Voice Features
+ G.711 a/μ-law, G.723.1, G.726, G.729A/B
+ DTMF Detection and Generation
+ Silence Suppression & Detection
+ Comfort Noise Generation (CNG)
+ Voice Activity Detection (VAD)
+ Echo Cancellation (G.165/G.168)
+ Adaptive (Dynamic) Jitter Buffer
+ Call Progress Tone Generation
+ Programmable Gain Control
+ Inbuilt Local Mixer
+ IVR
+ SNMP (Optional)
+ TR-069 /104 (Optional)
CALL FEATURES
+ Peer to Peer Call
+ Call Hold / Retrieve
+ Call Waiting
+ Call Pick Up
+ Call Park / Retrieve (SIP Server Required)
+ Call Forward - unconditional, busy, no answer
+ Call Transfer - attended, unattended
+ Do Not Disturb
+ Speed Dialing
+ Repeat Dialing
+ Three-way Calling
+ MWI (RFC-3842)
+ Hot Line and Warm Line
TELEPHONY FEATURES
+ In-Band DTMF, Out-of-Band DTMF Relay (RFC2833 or SIP INFO)
+ DTMF / PULSE Dial Support
+ Caller ID Generation
+ FSK-Bellcore Type 1 & 2
+ FSK-ETSI Type 1 & 2
+ FSK: Calling Name, Number, Date and Time, vMWI
+ T.30 FAX Bypass to G.711, T.38 Real Time FAX Relay
+ ROH Tone (Receiver Off-Hook Tone @ 480 Hz)
+ Loop Current Suppression
CALL MANAGEMENT
+ Support Outbound Proxy
+ Register up to three SIP servers
+ SIP Registration Failover Mechanism
+ Group Hunting
+ Privacy Mechanism / Private Extensions to SIP
+ Session Timers (Update / Re-invite)
+ DNS SRV Support
+ Call Types: Voice / Modem / FAX
+ Call Routing by Prefix Number
+ User Programmable Dial Plan Support
+ CDR Client
+ Manual Peer Table (for P2P calls)
+ E.164 Numbering, ENUM support
+ Symmetric RTP
ACCOUNT MANAGEMENT
+ By port registration
+ By device registration (share account)
+ Mixed mode (Hunt number for inbound, by port number for outbound)
+ Invite with Challenge
+ Register by SIP Server IP Address or Domain Name
+ Support RFC3986 SIP URI format
DIAGNOSTIC LEDs
+ Power
+ Register
+ Phone1
+ Phone2
QoS
+ TOS
+ 802.1P Priority Queues (8 queues)
+ Diffserv (DSCP)
+ Bandwidth control on WAN port
VLAN
+ VLAN Tagging in voice and data packets
DIMENSIONS
135 x 96 x 40 mm
WEIGHT
160 grams
POWER REQUIREMENT
12VDC 1A
POWER INPUT
100-240Vac, 50/60Hz, 1A,
POWER CONSUMPTION
+ 4.8W
OPERATING TEMPERATURE
0˚ to 45˚C (32˚ to 113˚ F)
STORAGE TEMPERATURE
-20˚ to 65˚C (-4˚ to 149˚ F)
OPERATING HUMIDITY
10% to 90% non-condensing
STORAGE HUMIDITY
5% to 95% non-condensing
EMISSION (EMI) CERTIFICATIONS
+ FCC Class B
+ CE
TELECOM CERTIFICATIONS
+ FCC Class B
+ CE
MTBH
+ 115486 Hrs
Certificates
Order info
DVG-5112S  2-port VoIP telephone adapter
Pictures
DVG-5112S
Front view
Downloads
Support Resources
