Quick find
Product features:
AC3200 Wi-Fi Ultra Router
EOL
Description:
Super-Charged with Smarter Wireless AC Features
Create a blazing fast home network that connects all of your computers and mobile devices to your broadband Internet connection. The newly introduced SmartConnect1 technology ensures that older wireless devices do not degrade the overall performance of the DIR-890L and allows wireless AC devices to have a total throughput of 3200 Mbps. The Advanced AC SmartBeam technology that is also in the DIR-890L brings you the future of high-bandwidth wireless connectivity, vastly increasing the speed and coverage of your network.
Use mydlink to Monitor Your Network
The AC3200 Ultra Wi-Fi Router is mydlink Cloud enabled, so you can effortlessly access and view your network no matter where you are. See who is connected to your router, change settings, or block someone from using your network connection, all from an Internet connected PC, tablet, or smartphone. Parents can monitor what sites their children are visiting, to stay informed and in control on the go.
File Sharing at Your Fingertips
The mydlink SharePort app allows you to connect a USB storage device to the DIR-890L and instantly share documents, movies, pictures, and music with mobile devices. Put your music library on a USB drive and share it with everyone else in your home, or show photos on the living room TV while a family member watches a movie on their mobile device.
Easy to Set Up and Use
Get the DIR-890L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your smartphone or tablet. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup.
Products | Support  | News  | About |
