DP-311UEOL EOS
Single-Port Wireless USB Print Server
Description
Flexible Installation
The DP-311U is ideal for both the large office and the small workgroup. For homes and SOHO with just one printer to share, this print server offers a single port and saves you the cost. For the large office with many computer users and several printers scattered at different places, you can plug one print server to each of these printers to share them on the network.
Ethernet and Wireless Interfaces
Two LAN interfaces are provided on this print server: (1) a 10/100Mbps Fast Ethernet port and (2) an 802.11b wireless LAN interface. This flexibly allows both Ethernet users and wireless users to print files through the DP-311U print server.
Wireless Network Security
The DP-311U provides the necessary security for wireless users, using the user-selectable 64/128-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol. Data privacy mechanism is based on a shared key algorithm, as described in the wireless LAN standard.
10/100Mbps LAN Port With Auto MDI/MDIX
Connection to the wired network is through a 10/100Mbps Fast Ethernet port, which automatically detects the speed of your network and auto-negotiates to use the highest speed available. This ports supports auto MDI/MDIX, eliminating for you the need to use a cross over cable. The DP-311U can easily plug to a hub or a switch, using any twisted-pair cable.
Multiple Network OS Support
The DP-311U supports as many network OS, including Windows 95, 98, ME, NT 4.0, XP , Apple MacOS with AppleTalk, Linux, Solaris, SCO Unix and NetWare 5.x native NDS. This gives you the flexibility to install the print server, regardless of your network environment.
Easy Setup
Setup the print server is easy with a Windows-based menu-driven program, which guides you through all the necessary steps to set up and configure your network printer. SNMP and latest MIB-II MIBs are also built into the print server, allowing you to manage this device on any SNMP standard-based network.
General features
Certificates
Order info
Pictures
DP-311U
Front view
Downloads
Support Resources
