DGS-1024TEOL EOS
24-Port Gigabit Switch
Tanımlama
D-Link's next generation Web Smart Gigabit switch series blends plug-and-play simplicity with exceptional performance and reliability for small and medium-sized business (SMB) networking. With 3 models to choose from, this series provides flexible choices for different network size requirements. All models are housed in a new style rack-mount metal case with easy-to-view front-panel diagnostic LEDs, and provide advance features including up to 4 combo SFP fiber connections, network security, traffic segmentation, QoS and versatile management.
A Switch for Each Business Size. Choices of 16, 24 and 48 copper Gigabit ports are available for selection. Supporting the Cat. 5 copper twisted-pair cables with auto-detection of MDI/MDIX, these switches bring inexpensive and easy Gigabit connection to the desktops. Each switch provides 2 or 4 combo SFP slots for flexible connection to a fiber backbone or servers.
Extensive Layer 2 Features. Implemented as complete L2 devices, these switches include functions such as Jumbo frame support, IGMP snooping, port mirroring, Spanning Tree, port trunks and 802.3x Flow Control to enhance performance and network resiliency.
Traffic Segmentation and QoS. The switches support 802.1Q VLAN T agging for traffic segmentation by groups to enhance network security and performance. They also support 802.1p Priority Queues, enabling users to run bandwidth-sensitive applications such as streaming multimedia and VoIP on the network. These functions allow the switches to work seamlessly with managed VLAN and 802.1p traffic on the network.
Network Security. The switches provide MAC address filters screen access to the network. They support 802.1x port-based authentication, allowing the network to be configured with external RADIUS servers. Additional features like D-Link Safeguard Engine protect the switches against traffic flooding caused by virus/worm outbreaks.
Versatile Management. Switch configuration and management is through the SmartConsole Utility or a web-based GUI. SmartConsole is an easy way to access the switch from a local PC; users do not have to type in any IP address or subnet, and all switches connected on the network are displayed on the screen for instant access. The web-based GUI allows switch access from any location on the network or from a remote site, using a web-browser. It allows extensive switch configuration setting, which can be backed up for duplication in other switches.
In addition, users can also use the built-in MIB to poll the switches for information about their status and send traps of  abnormal events. MIB support allows users to integrate the switches with other  third-party devices for  management in an SNMP environment.
Genel Özellikler
Standards
- IEEE 802.3 10BASE-T Ethernet (cat. 3 copper)
- IEEE 802.3u 100BASE-TX Fast Ethernet (cat. 5 copper)
- IEEE 802.3z 1000BASE-SX/LX Gigabit Fast Ethernet
  (Multi-mode/single-mode filber)
- IEEE 802.3ab 1000BASE-T Gigabit Ethernet (cat. 5 copper)
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet:
  10Mbps (half duplex)
  20Mbps (full duplex)
- Fast Ethernet:
  100Mbps (half duplex)
  200Mbps (full duplex)
- Gigabit Ethernet:
  2000Mbps (full duplex)
Topology
Star
Network Cables
- 10BASE-T:
  UTP Cat. 3, 4, 5 (100 m max.)
  EIA/TIA-586 100-ohm STP (100 m max.)
- 100BASE-TX, 1000BASE-T:
  UTP Cat. 5, Cat. 5e (100 m max.)
  EIA/TIA-568 100-ohm STP (100 m max.)
- IEEE 802.3z:
  Single-mode and multi-mode fiber
Full/half Duplex
- Full/half duplex for 10/100Mbps speeds
- Full duplex for Gigabit speed
Media Interface Exchange
Auto MDI-II/MDI-X adjustment for all copper Gigabit ports
Twisted-pair Rx Reverse Polarity
Auto-correction
Number of Ports
- 22 dedicated 10BASE-T/100BASE-TX/1000BASE-T ports
- 2 combo RJ-45/mini GBIC supporting 10BASE-T/100BASE-
  TX/1000BASE-T and fiber Gigabit
LED Indicators
- Per port:
  100Mbps speed
  1000Mbps speed
  Full Duplex
  Link/Act
- Per device:
  Power
Transmission Method
Store-and-forward
MAC Address Table
32K entries per device
MAC Address Learning
- Automatic update
- Max Age: 300 sec.
Packet Filtering/Forwarding Rates (half duplex)
- Ethernet: 14,880 pps per port
- Fast Ethernet: 148,810 pps per port
- Gigabit Ethernet: 1,488,100 pps per port
RAM Buffer
2Mbytes per device
Çözümler
Sipariş Bilgisi
Copper Gigabit Switch
DGS-1024T
  22  RJ-45 10/100/1000Mbps ports, 2 combo RJ-45/mini GBIC  supporting copper, 10/100/1000Mbps and fiber Gigabit
Optional Modules
DEM-310GT Single-Mode 1000BASE-LX Mini-GBIC Gigabit Ethernet Module
DEM-311GT Multi-Mode 1000BASE-SX Mini-GBIC Gigabit Ethernet Module
Görseller
DGS-1024T
Front view
Back view
İndir
Destek Merkezi
