Hızlı Arama
Ürün Özellikleri:
Unified Switch to manage the access points level 2 + 20-port 10/100/1000Base-T (PoE) + 4 Combo 10/100/1000Base-T/SFP, supports up to 48 access points
Genel Özellikler:
MTBF
282.541 h
Acoustics
• Below 30 ° C <39,8 dB
• Above 30 ° C <51,8 dB
Heat release
With a capacity of 370 W PoE: 1593,5 BTU / hour
Measurements
440 x 310 x 44 mm
Weight
5.24 kg
Operating temperature
0 to 50 C
Storage temperature
-40 To 70 C
Operating Humidity
From 10% to 90% RH
Humidity
From 5% to 90% RH
Electromagnetic safety
• FCC Class A
• CE
• ICES-003
• C-Tick
• VCCI
Safety
• UL / cUL
• CB
Fiziksel Özellikler
Size
Width for 19 "standard rack, 1U height
Interface
• 20 ports of 10/100/1000BASE-T (PoE)
• 4 combo ports 10/100/1000BASE-T/SFP
The console port
RJ-45
Table MAC-addresses
16K
Max. power consumption
467 W (when all the ports PoE)
Performance
• Switch fabric: 48 Gbit / s
• The speed of packet forwarding: 35,71 Mpps
• Switching Method: Store and Forward
• Size of the packet buffer size: 2 MB
• 802.3af Power over Ethernet
  - 15.4 W per port
  - 370 watts total power budget
  - 740 watts total power budget (using a backup power supply (RPS))
• The number of VLAN on the device: 3,965
• Static routes: 512
• Jumbo-size frames: 13K
Software
Management
• Up to 48 standardized wireless access points to a switch (12 DT default DT increase to 48 by using additional licenses) to access point 192 to the cluster
• The cluster-enabled switches Single IP Management (SIM, management through a single IP-address)
• SSH
• SSL
• SNMP v1, 2c, 3
• sFlow
• Support of the copies (Dual Image)
• Web-interface
• Command Line Interface
Management of TD
• Automatic detection of AP
• Remote Reboot AP
• Monitoring TD: List of managed access points, rogue access points, unauthenticated access points
• Monitoring of clients: List of clients connected to each managed AP
• Monitoring client Ad-hoc
• Authentication of access points to the local database and an external RADIUS server
• Centralized management of security policies / RF
• Automatic tuning of radio frequency channels for access points
• Automatically adjusts the output power of the transmitter
• Centralized software update
Managed Unified Access Point
• DWL-2600AP
• DWL-3600AP
• DWL-6600AP
• DWL-8600AP
Roaming
• Fast Roaming
• Roaming between switches and access points that are connected to the same switch
• Inside - roaming and internetworking
Access control and bandwidth
• Up to 32 SSID on the access point (SSID 16 to the RF channel)
• Load balancing between access points based on the number of users or the use of TD
• Wiring
Layer 2 Features
• IGMP Snooping
• MLD Snooping
• 802.1D/w/s Spanning Tree
• 802.3ad Link Aggregation
• 802.1ab LLDP
• Port Mirroring (One-to-One and Many-to-One)
• Jumbo-size frames: up to 13 MB
Layer 3 Features
• A static route IPv4/v6
• Routing table size: 512 static routes
• VRRP
• ARP Proxy
LAN Security
• RADIUS authentication for administrative access
• TACACS + authentication for administrative access
• SSH and SSL
• Filtering by MAC-address-
• Access Control 802.1x port-based and Guest VLAN
• Protection against DoS attacks
• Dynamic ARP Inspection
• Secure Port
• Broadcast Storm Control
• Access control lists (ACL)
Flow Control
• 802.3x flow control in full duplex mode
• The method of "back pressure" in the half-duplex mode
• Blocking Prevention Head-of-Line
QoS
• Voice VLAN
• Wireless Multimedia (WMM)
• 802.1p Priority Queues
• CoS-based QoS
• Bandwidth management on the basis of flow
• Traffic shaping on port
• The minimum bandwidth guarantee for all
VLAN
• 802.1Q VLAN Tagging
• 802.1V
• VLAN-based subnets
• VLAN for MAC-based
• GVRP
• Double VLAN
• Voice VLAN
WLAN Security
• WPA Personal / Enterprise
• WPA2 Personal / Enterprise
• 64/128/152- bit WEP-encryption
• Authentication based on MAC addresses
• Insulation Station
• Classification of the wireless stations and access points based on the channel, MAC-address, SSID, time
• Detect and minimize unauthorized access points and clients
• Adaptive portal
• The safety profile
• 802.1X
• Guest VLAN
Ürünler | Destek  | Haberler  | Hakkında |
