DEM-X40CS-1471EOL
Transceiver 10G SFP + CWDM single mode optical cable (wavelength 1471nm, up to 40 km)
Nereden Alınır
Tanımlama
Series 10G CWDM SFP + / XFP Module D-Link - it transceivers, hot swappable, which are installed in the ports of SFP + or XFP switch and provide job Ethernet networks at 10 Gb / s. These transceivers can be used with CWDM optical multiplexer to combine signals from multiple Ethernet ports on the switch for transmission over a single fiber, which significantly reduces the cost of the infrastructure used for fiber optic data transmission over long distances. This line includes transceivers to operate at different wavelengths (wavelength used is determined by the model), which is ideal for problem solving and application providers on campus.
Speed ​​10 Gb / s
The transceivers are designed to work in networks of 10-Gigabit Ethernet, which allows for very fast data transfers. A ten-fold increase compared with 1 Gbit / s allows the switch to faster and in greater volume to handle data streams.
Hot Plug
All D-Link transceivers support hot-plug capability. Connect the transceiver to a powered device will not cause any problems.This allows you to connect or disconnect the transceiver without disrupting the rest of the network.
Genel Özellikler
Fiziksel Özellikler
Standard
• Compliant with: IEEE-802.3ae, 10GBASE-SR
• Transceiver type: SFP +
• The standard for Fibre Channel FC-PI: 1200-SM-LL-L
• Support for fiber-optic cable: Single Mode
• Transmission distance: 40 km
Capabilities
• Hot Plug
• Compatible with MSA
• Compliant with RoHS
Speed
10 Gbit / s
Interfaces
• Connector: Duplex LC Connector
• uni-/bidirectional: Uni-
• The wavelength of 1471 nm
• Output power (TX)
   Max. 4 dBm
   Min.: 0 dBm
• Optical input (RX)
   Max.: -1 DBm
   Min.: -16.4 DBm
• Sensitivity: -16.4 dBm
• Cable type: single-mode optical 9/125 micron
Compatibility with switches and modules
DGS-3420-26SC, DGS-3420-28SC, DGS-3420-28TC, DGS-3420-28PC, DGS-3420-52T, DGS-3420-52P, DGS-3620-28TC, DGS-3620-28TC-DC, DGS-3620-28SC, DGS-3620-28SC-DC, DGS-3620-28PC, DGS-3620-52T, DGS-3620-52P, DXS-3600-16S, DXS-3600-32S, DGS-6600-24SC2XS, DGS-6600-24SC2XS-C, DGS-6600-16XS-DBR
Fiziksel Özellikler
Nutrition
3.3
Max. input current
3.3 V: 600 mA
Min. power budget
16.4 dB
Max. power budget
20.4 dB
Heat release
7.13 kJ / hr
MTBF (Hours)
1,580,000
Operating temperature
From 0 to 70C
Storage temperature
-40 To 85C
Operating Humidity
From 0% to 85%
Humidity
From 0% to 85%
Dimensions (W x D x H)
13.7 x 56.5 x 8.5 mm
Weight
20 grams
EMI
CE
Safety
UL, TUV, FDA / CDRH
Çözümler
Sipariş Bilgisi
Görseller
DEM-X40CS-1471/A
Front view
İndir
Destek Merkezi
