Hızlı Arama
Ürün Özellikleri:
16 10/100BASE-TX portu ve güç tasarrufu fonksiyonu ile yönetilmeyen Anahtar
Genel Özellikler:
Fiziksel Özellikler
Key Features
• Cost-effective Fast Ethernet for home networks and SOHO
• Auto MDI / MDIX on all ports
• Switching Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• The Plug-and-play
Switching
3.2 Gbit / s
Standards
• ANSI / IEEE 802.3 NWay auto-negotiation of speed and mode
Protocol
CSMA / CD
Data rate
• Ethernet:
 - 10 Mbps (half duplex)
 - 20 Mbps (full duplex)
• Fast Ethernet:
  - 100 Mbps (half duplex)
  - 200 Mbps (full duplex)
Number of Ports
16-Port 10/100Mbps Fast Ethernet
Topology
Star
Network Cables
• 10BASE-T:
  - UTP Cat. 3/4/5/5e (100m max.)
  - EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX:
  - UTP Cat. 5/5e (100m max.)
Interfaces transmission medium
Automatic detection of MDI / MDIX on all ports
Indicators
• In the Port:
  - Link / Activity
• On the device:
  - Power
Switching Method
Store-and-forward
Table MAC-addresses
8K device
Study of MAC-addresses
Automatic updates
Speed ​​Packet Filtering / Forwarding (half duplex)
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
Buffer RAM
256KB (2Mbit)
Fiziksel Özellikler
Power Input
100 ~ 240 VAC, 50/60 Hz internal universal power supply
Power consumption
• Power on. (Standby): Power Input: 0.61 W DC 1.19 W ac
• Max.: Power Input: 1.55 W DC 2.89 W ac
Heat release
• Power on. (Standby): 4.06 BTU / h
• Max.: 9.86 BTU / h
MTBF
2,266,559 hours
Operating temperature
From 0 º to 40 º C
Storage temperature
From -10 ˚ to 70 ˚ C
Operating Humidity
From 10% to 90%, non-condensing
Humidity
From 5% to 90%, non-condensing
Measurements
280 x 125.8 x 44 mm
Certifications
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• VCCI Class A
• cUL
• LVD
Mount for mounting in a 19 "rack is supplied with the device
Ürünler | Destek  | Haberler  | Hakkında |
