Hızlı Arama
Ürün Özellikleri:
16 Adet 10/100/1000Base-T portu ile Yönetilmeyen Layer 2 Gigabit Ethernet Anahtar
Genel Özellikler:
Fiziksel Özellikler
Key Features
• Technology D-Link Green
  - Definition of the connection status and cable length
• Inexpensive Gigabit solution for home networks and SOHO / SMB
• passive cooling system ensures quiet operation
• Auto MDI / MDIX on all ports
• Switching Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• Jumbo-9600 byte frames
• Supports IEEE 802.1p QoS (4 queues, Strict Mode)
• Cable Diagnostics
• Support for EEE +
• Compliance with the RoHS Directive
• Plug-and-play
• The button "ON / OFF" on the front panel to turn on / off the EEE + (Energy-Efficient Ethernet) mode
• Kensington Lock
• Fixing to the ground cable to the back of the unit
Number of Ports
16-port Gigabit
Switching matrix
32 Gbit / s
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI / IEEE 802.3 NWay auto-negotiation of speed and mode
• Flow Control IEEE 802.3h
• IEEE 802.1p QoS (4 queues, strict mode)
• IEEE802.3az EEE
Protocol
CSMA / CD
Data rate
• Ethernet:
  10 Mbit / s (half duplex)
  20 Mbit / s (full duplex)
• Fast Ethernet:
  100 Mbit / s (half duplex)
  200 Mbit / s (full duplex)
• Gigabit Ethernet:
  2000 Mbit / s (full duplex)
Topology
Star
Network Cables
• 10BASE-T:
  UTP Cat. 3,4,5,5 e (100m max.)
  EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX, 1000BASE-T:
  UTP Cat. 5/5e (100m max.)
Interfaces transmission medium
Automatic detection of MDI / MDIX on all ports
Indicators
• Per port: Link / Activity / Speed
• On the device: Power
Switching Method
Store-and-forward
Table MAC-addresses
8K entries per device
Study of MAC-addresses
Automatic updates
Speed ​​Packet Filtering / Forwarding (half duplex)
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
• Gigabit Ethernet: 1488000 packets per second. the port
Buffer RAM
512 Kbytes to the device
Fiziksel Özellikler
Power consumption
• Standby mode: 3.8 W
• Max.: 11.0 W
Heat release
• Standby: 12,958 BTU / h
• Max.: 37,51 BTU / h
Noise level
0 dB
MTBF
1087450 h
Operating temperature
From 0 º to 40 º C
Storage temperature
From -10 ˚ to 70 ˚ C
Humidity
From 5% to 90%, non-condensing
Measurements
280 x 180 x 44 mm
Weight
1.59 kg
Certifications
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• cUL
• CB
Mount for mounting in a 19 "rack is supplied with the device
Ürünler | Destek  | Haberler  | Hakkında |
