Hızlı Arama
Ürün Özellikleri:
SFP module with 1-port 1000Base-BX, for single-mode fiber optic cable, 3.3V (up to 2 km), WDM (Tx: 1310 nm, Rx: 1550 nm)
Genel Özellikler:
Fiziksel Özellikler
Standards
IEEE-802.3z, 1000BASE-BX
Type form factor
SFP
Support for fiber optic cable
Single-mode
Transmission distance
2 km
Capabilities
• Hot Plug
• Compatible with MSA
• Compliant with RoHS
Speed
1 Gbit / s
Jack
Simplex LC
Uni-/bidirectional
Bilateral
Wavelength
• TX: 1310nm
• RX: 1550
Output power (TX)
• Max.: -3 DBm
• Min.: -10 DBm
Optical input (RX)
• Max.: -3 DBm
• Min.: -21 DBm
Sensitivity
-21 DBm
Type of cable
• Single-mode optical
• 9/125 m, distance: 2 km
The physical parameters
Nutrition
3.3
Max. input current
300 mA
Min. power budget
11 dB
Max. power budget
18 dB
Heat release
1,782 kJ / h
MTBF
213222 h
Operating temperature
From 0 to 70 ° C
Storage temperature
-40 To 85 C
Operating Humidity
From 5% to 95%
Humidity
From 5% to 95%
Dimensions (W x D x H)
13,5 x 56,6 x 8,5 mm
Weight
21 grams
Ürünler | Destek  | Haberler  | Hakkında |
