Hızlı Arama
Ürün Özellikleri:
Module 1-port XFP 10G (10GBASE-ER) for single mode fiber optic cable (up to 80 km)
Tanımlama:
Transceiver D-Link DEM-424XT is designed for installation in equipment for networks 10 GE, equipped with a special expansion slots. It supports standard IEEE 802.3ae 10GBASE-ER and transmits data over single mode optical fiber at distances up to 80 km.The transceiver complies with the Small Form Factor Pluggable (XFP) and compatible with the Multi-Source Agreement (MSA).
Data transmission over optical fibers
This transceiver is intended for installation in equipment with slots XFP, and performs data transmission on the single mode optical fiber at a wavelength of 1550 nm. It supports voltage +3.3 V and +5 V and is compatible with standard Multi-Source Agreement (MSA) Small Form Factor Pluggable (XFP). The transceiver includes an optical transmitter and an optical receiver circuitry. It is placed in a metal casing, which provides reliability of the device.
Wide range of applications
10 Gigabit Ethernet transceiver can be used to build high-speed optical backbones networks LAN, WAN and MAN connectivity and performance servers and data centers.
Ürünler | Destek  | Haberler  | Hakkında |
