Hızlı Arama
Ürün Özellikleri:
8 port 10/100/1000 Base-T ve güç tasarrufu fonksiyonu ile yönetilmeyen Anahtar
Genel Özellikler:
Fiziksel Özellikler
Key Features
• Built-in D-Link Green
• Inexpensive Gigabit solution for home networks and SOHO
• 8-port 10/100/1000 Mbit / s Gigabit
• Switch Fabric 16 Gb / s
• Auto MDI / MDIX on all ports
• Switching Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• Jumbo-frames 9216 byte (only at 1000 Mb / s)
• Supports IEEE 802.1p QoS (4 queues, Strict Mode)
• Supports Cable Diagnostics
• Compliance with the RoHS Directive
• The Plug-and-play
Standards
• IEEE 802.3ab 1000BASE-TX Gigabit Ethernet (twisted-pair copper)
• ANSI / IEEE 802.3 NWay auto-negotiation of speed and mode
• Flow Control IEEE 802.3h
• IEEE 802.1p QoS
Protocol
CSMA / CD
Data rate
• Ethernet:
  -10 Mbit / s (half duplex)
  -20 Mbit / s (full duplex)
• Fast Ethernet:
  -100 Mbit / s (half duplex)
  -200 Mbit / s (full duplex)
• Gigabit Ethernet:
  -2000 Mb / s (full duplex)
Topology
Star
Network Cables
• 10BASE-T:
  - UTP Cat. 3/4/5/5e (100m max.)
  - EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX, 1000BASE-T:
  - UTP Cat. 5/5e (100m max.)
Interfaces transmission medium
Automatic detection of MDI / MDIX on all ports
Indicators
• In the Port:
  - Link / Activity / Speed
• On the device:
  - Power
Switching Method
Store-and-forward
Table MAC-addresses
8K entries per device
Study of MAC-addresses
Automatic updates
Speed ​​Packet Filtering / Forwarding
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
• Gigabit Ethernet: 1488000 packets per second. the port
Buffer RAM
192 Kbytes to the device
Fiziksel Özellikler
Power Input
5V/1A DC external power adapter
Power consumption
• Power on. (Standby)
  - Input Power: 0.59 W DC 1.5 W AC
• Max.:
  - Input Power: 3.48 W DC, 5.4 W AC
Heat release
• Power on. (Standby): 5.22 BTU / h
• Max.: 18.25 BTU / hr
MTBF
522,270 hours
Operating temperature
from 0 º to 40 º C
Storage temperature
From -10 ˚ to 70 ˚ C
Humidity
• Operating: 10% to 90%
• Storage: 5% to 90%
Measurements
120 x 80 x 28 mm
Certifications
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• LVD
• CB
Ürünler | Destek  | Haberler  | Hakkında |
