DGS-6600-CM-IIProje
CPU Module for DGS-6600 Series
Tanımlama
Genel Özellikler
• Switching Capacity: 480Gbps • 1x Female DCE RS-232 DB-9 console port • 1x Female USB series type B console port • 1 x RJ-45 Out-of-band management port for out-of-band SNMP / Web / Telnet management • 2 CF card slots for portable images and configurations files • CPU: 1.3GHz • RAM: 2GB • Flash memory: Prom 4MB, Runtime 1GB (internal CF card) Fiziksel Özellikler Power Consumption Max: 53.856W Heat dissipation 183.6BTU/hr MTBF (hours) 263,581 Operating temperature 0 to 50°C Storage temperature -40 to 70°C Operating humidity 10% to 90% non-condensing Storage humidity 5% to 90% non-condensing
Çözümler
Sipariş Bilgisi
Görseller
DGS-6600-CM-II/A
Front view
İndir
Destek Merkezi
