Hızlı Arama
Ürün Özellikleri:
24 Port 10/100 Switch
Genel Özellikler:
Device Interfaces
• 24 10/100 Base-TX ports
LAN
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX compliance
• IEEE 802.3x Flow Control support
Data Transfer Rates
• Fast Ethernet
  • 100 Mbps Half-Duplex
  • 200 Mbps Full-Duplex
• Ethernet
  • 10 Mbps Half-Duplex
  • 20 Mbps Full-Duplex
Port Packet Filtering/ Forwarding Rate
• 148,800 pps for 100 M
• 14,880 pps for 10 M
Fiziksel Özellikler
Dimensions
• 231 x 158 x 46 mm (9.09 x 6.22 x 1.81 inches)
Weight
• 480 grams (1.06 lbs)
Power Consumption
• Power On (Standby):
  • DC input: 0.55 watts
  • AC input: 1.21 watts
• Maximum:
  • DC input: 1.65 watts
  • AC input: 2.69 watts
Heat Dissipation
• Power On (Standby): AC input: 4.133 BTU/h
• Max.: AC input: 9.19 BTU/h
MTBF
• 583,598 hours
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -10 to 70 °C (14 to 158 °F)
Humidity
• Storage: 5% to 90% non-condensing
Certifications
• CE
• CB
• FCC
• C-Tick
• cUL
Ürünler | Destek  | Haberler  | Hakkında |
