DGS-1024DEOL EOS
24-Port 10/100/1000 Mbps Unmanaged Switch
Tanımlama
The DGS-1024D 24-Port Gigabit Unmanaged Desktop Switch offers an economical way for SOHO and small to medium businesses (SMB) to benefit from the increased bandwidth of Gigabit Ethernet. The DGS-1024D provides 24 Gigabit ports for fast server deployment to meet increasing network loads.
Think Green
D-Link’s DGS-1024D is part of a new series of SOHO/SMB devices that make use of D-Link’s Green Ethernet technology, featuring IEEE802.3az EEE and EEE+ modes to provide more energy savings and a longer product life without sacrificing operational performance or functionality. IEEE802.3az EEE is a power-saving feature that reduces energy use when the switch is at low utilization. EEE+ is a power-saving feature that is similar to IEEE802.3az EEE. However, unlike EEE, EEE+ can function regardless of whether the switch’s link partner is EEE-compliant or not. Recyclable packaging and minimized use of harmful substances (RoHS compliant) make this switch truly environmentally friendly.
Conserves Energy
By building on the foundation of D-Link’s Green Ethernet technology, the DGS-1024D helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjusts power usage accordingly, helping you save energy without affecting networking performance. This helps you reduce your power usage and your energy bill.
Environmentally Friendly
The DGS-1024D was designed with the environment in mind, and was built to follow RoHS standards to minimize the use of hazardous materials. It uses recyclable packaging that helps reduce waste, and complies with the WEEE directive.
IEEE 802.1p QoS
QoS prioritizes network traffic so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. This helps ensure an optimal experience for streaming media, VoIP calls, and online gaming.
Cable Diagnostics Function
The D-Link Cable Diagnostics Function enables users to efficiently detect cable conditions through the LEDs on the front-panel. Users can determine whether the pin connections of their cables’ connectors are correct, facilitating network troubleshooting.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DGS-1024D/G1
Front view
View from the right
Back view
DGS-1024D/G2
Front view
View from the right
Back view
İndir
Destek Merkezi
