DES-1008EOL
Unmanaged 10/100Mbps Switch
Tanımlama
Plug-and-Play
This switch is designed to enhance workgroups' performance while providing a high level of flexibility. Powerful yet easy to use, it allows users to simply plug any port to either a 10Mbps or 100Mbps node to multiply bandwidths, boost response time and satisfy heavy load demands.
Complete Flexibility
All ports support the NWay standard. They automatically negotiate between 10BASE-T and 100BASE-TX network speeds, as well as between full and half duplex modes. Any port thus can act as an uplink to Fast Ethernet or downlink to Ethernet.
Workgroup Client-Server
This switch is ideal for deployment of multiple high-speed servers for shared  bandwidth 10Mbps or 100Mbps workgroups. In 200Mbps full- duplex mode, any port can provide workstations with a congestion-free data pipe for simultaneous access to the server.
Genel Özellikler
Features
-8 10/100Mbps ports
- Full/half duplex support for each port
- Completely plug-and-play
- MDI uplink port for easy expansion
- Auto-correction of Rx polarity reverse
- UTP, STP supported
- Extensive front-panel diagnostic LEDs
- Internal universal power supply
- FCC Class A, CE Mark, VCCI
Class A, C-Tick
- UL, CSA, TUV/GS
- Compact desktop size
Performance
- Store-and-forward switching method
- RAM buffer dynamically allocated for each port
- Auto-learning of network configuration
- Packet filtering/forwarding rates:
148,800 pps per port (in half duplex)
- Filtering address table: 8K per device
- RAM buffer: 2MB per device
Çözümler
Sipariş Bilgisi
DES-1008 Unmanaged 10/100Mbps Switch
Görseller
DES-1008
View from the right
İndir
Destek Merkezi
