DES-1016D/RVEOL EOS
16-Port 10/100BASE-T Unmanaged Switch With isolated-VLAN port
Tanımlama
This 16-Port 100BASE-T Fast Ethernet Switch is designed for the departmental and enterprise connection, Powerful and versatile, it eliminates network bottlenecks while giving users the capability to fine-tune performance.
Desktop size is especially suitable for departmental environment, providing users the best performance/price ratio. Clear, at-a-glance per-device/per-port LED indicators make users easier to understand and control network status.
Genel Özellikler
Number of Ports
16-Port 10/100Base-T
Port packet Filtering/Forwarding Rate
- 14,880 pps for 10M
- 148,809 pps for 100M
AC input
100 to 240 VAC, 50 or 60 Hz internal universal power supply
Power Consumption:
6.8 Watts
Operation Temperature
0-40°C
Storage Temperature
-10 -70°C
Dimension
- 280 mm x 180 mm x 44 mm
- 1U, 11” Rack-mount Size
Humidity
- Operating: 10% ~ 90%
- Storage: 5% ~ 90%
Emission (EMI) and Safety Certifications:
- EMI: FCC Class A, CE, VCCI
- Safety: cUL
Çözümler
Sipariş Bilgisi
DES-1016D/RV   16-Port 10/100BASE-T Unmanaged Switch With isolated-VLAN port
Görseller
DES-1016D/RV/D
Front view
Back view
İndir
Destek Merkezi
