DES-3225GEOL EOS
24-Port Fast Ethernet Switch
Tanımlama
24 Auto-sensing 10/100Mbps Ports
This standalone switch provides a maximum of 24 NWay ports that automatically negotiate between 10BASE-T and 100BASE-TX network speeds, as well as between full and half duplex modes. The available plug-in modules are :
l. 2 port 10/100Mbps board
2. 1 port 100BASE-FX board
3. 2 port 100BASE-FX board
4. 1 port Gigabit Ethernet board
Departmental Connection
The switch is a low-cost solution for departmental connection that can handle network speeds of up to 2000Mbps (full-duplex gigabit Ethernet) and provide high bandwidth to multiple workgroup segments. It can also provide dedicated full-duplex Fast Ethernet links to multiple server farms for bandwidth intensive client-server applications.
User-customizable Filters
With layer 2 switching capabilities in addition to dynamic filtering through auto-learned MAC addresses, the switch also supports static filtering, permitting the administrator to define custom filters to set up network security and implement explicit forwarding.
Industry-standard Management
SNMP agent permits the switch to be part of a larger network with configuration control and traffic monitoring. In addition, remote monitoring capability is built into every segment, allowing easy implementation of RMON. Built-in HTTP server provides an easy-to-use Web-based management interface through a standard web browser.
Broadcast Storm Protection
The administrator can select to forward or discard multicast packets on all or specific segments to flexibly control broadcast data and prevent unnecessary absorption of network bandwidth.
VLAN Support
With virtual LAN support, the administrator can enhance security and create logical workgroups regardless of the users’ physical locations. This permits mobile users to simply plug into any wall socket to access the network, while remaining part of their original groups within an organization’s structure.
Genel Özellikler
Standards
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE- TX Fast Ethernet
- IEEE 802.3z 1000BASE-SX Gigabit Ethernet
- IEEE 802.3x full-duplex flow control
- IEEE 802.1 p Priority Queue
- IEEE 802.1Q VLAN Tagging
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet
  10Mbps (half duplex)
  20Mbps (full duplex)
- Fast Ethernet
  100Mbps (half duplex)
  200Mbps (full duplex)
- Gigabit Ethernet
  1000Mbps (half duplex)
  2000Mbps (full duplex)
Topology
Star
Network Cables
- 10BASE-T:
  2-pair UTP Cat. 3, 4, 5 (100 m)
  EIA/TIA-568 100-ohm STP (100 m)
- 100BASE-TX:
  2-pair UTP Cat. 5 (100 m)
- 100BASE-FX
  Multimode cable ISO/IEC 793-2 type A 1 a and ITU-T G.652
  standards with SC connector
- 1000BASE-SX
  Multimode cable ISO/IEC 793-2 type A 1 b and ITU-T G.652 standards with SC connector
Number of Ports
- Maximum 24 Fast Ethernet RJ-45 ports
- Maximum 2 Fast Ethernet Fiberoptic Transceiver ports
- Maximum 1 Gigabit Ethernet Fiberoptic Transceiver ports
- 1 RS-232 management port
10/100Mbps Selection
Auto-negotiation
Full/half Duplex Selection
Auto-negotiation
LED Report
- Per port:
  100Mbps (speed)
  Link/activity
- Per system:
  Power
  Console
  Giga
  Slot2
Performance
Transmission Methods
Store-and-forward
RAM Buffer
- Packet Buffer:
  0.5MB per 10/100Mbps port
  2MB per 1000Mbps port
Filtering Address Table
- 12K MAC addresses (max.)
MAC Address Table
- Dynamic entries: auto-learned
- Static entries: user-definable
Management Standards
- SNMP
- IEEE 802.1d Spanning Tree Protocol
- Trivial File Transfer Protocol (TFTP)
- RMON Group 1, 2, 3, 9 (Alarm, Statistics, History,Event)
MIBs
- MIB-II: RFC 1213
- Bridge MIBs: RFC 1493
- RMON MIBs: RFC1757
- D-Link Enterprise MIBs
Console Port
DB-9 RS-232 DCE x 1
Çözümler
Sipariş Bilgisi
Stand-alone 10/100Mbps Switches
DES-3225G
  24 10/100Mbps ports, SNMP, RMON agents
Optional Modules
DES-362FM
  2 100BASE-FX fiber ports (MT-RJ connector)
DES-3251G   1 1000BASE-SX Gigabit fiber port
Görseller
DES-3225G
Front view
İndir
Destek Merkezi
