DKVM-IP8EOL
8/16 Port IP Combo KVM (USB Local Console)
Tanımlama
DKVM-IP8 defines a new class of remote KVM access device; it combines digital remote KVM access via IP networks with comprehensive and integrated system management.
DKVM-IP8 owes a convenient, remote KVM access and control via LAN or Internet. It captures, digitizes, and compresses video and transmits it with keyboard and mouse signals to and from a remote computer. Also it provides a non-intrusive solution for remote access and control. Remote access and control software runs on its embedded processors only but not on mission-critical servers, so that there is no interference with server operation or impact on network performance.
Genel Özellikler
PC Connection
Direct
8
Max. via Daisy Chain
120 (8 port + 16 port * 7 levels)
Port Selection
Push button, Hotkey, OSD
Connectors
Console
Keyboard
1*Mini Din 6 Female (Purple)
Video
1*HDB15 Female (Blue)
Mouse
1*Mini Din 6 Female (Green)
Computer
8*SPHD 15 pin Female (Blue)
Daisy Chain
Keyboard
Video
Mouse
Serial Port
1*DB9 pin Male
USB Port
1*USB 2.0 Type B
LAN
1*RJ-45 Female
Power
1*DC Jack (Black)
Emulation
Keyboard / Mouse
PS/2
LED
Online
8
10 / 100 Mbps
1 (Orange / Green)
7-Segment
1
Scan Intervals
5~99 Sec
Reset button
1
VGA Resolution
• l Local: 1600*1200
• l Remote: 1280*1024
Environment
Operation Temperature
0 ~ 5°C
Storage Temperature
-20 ~ 60°C
Humidity
0 ~ 80%, Non-Condensing
Power Adapter
DC 5V, 2.5A
Physical Properties
Housing
Metal
Weight
2,600g
Dimensions (L*W*H), mm
44*430*220
Çözümler
Sipariş Bilgisi
DKVM-IP8  8/16 Port IP Combo KVM (USB Local Console)
Görseller
DKVM-IP8/Tx
Front view
Left side view
Back view
İndir
Destek Merkezi
