Hızlı Arama
Ürün Özellikleri:
The DCM-704B Wireless N Cable Router EMTA is DOCSIS/EuroDOCSIS 3.0
Genel Özellikler:
Fiziksel Özellikler
DEVICE INTERFACES
 1 F-type female 75 ohm connector
  2 RJ-11 Telephone Socket
  4 10/100 BASE-TX Ethernet ports
  1 USB 1.1 port
  802.11g module as AP in miniPCI
interface
Power ON/OFF switch
HARDWARE FEATURES
  PacketCable 1.5 Standard Compliant
  DOCSIS/EuroDOCSIS 3.0 standard compliant
  Support PacketCable MGCP (Media Gateway Control Protocol)
  SIP (Session Initiation Protocol) Compliant
  D4x Standard RJ-45 connector for
10/100BaseT Ethernet with autonegotiation MDIX functions
  USB 2.0 (Available for NAS functionality – Optional)
  Two RJ-11 Foreign Exchange Station (FXS) ports for IP telephony
  QoS enhancement
  MSO SNMPv3 remote network management
  Provide MIBs DOCSIS1.0/1.1/2.0/3.0
  Support simultaneous voice and data communications
  Echo Cancellation
  Voice Active Detection (VAD)
  Comfort Noise Generation (CNG)
  Web browser Management auto detect network status
  WPS (Wireless Protection Setup) Supported
  Multi-SSID Supported
  Parental Control Supported
RECIEVER
  Demodulation 64/256QAM
  Max Speed:
  171.52(+152) Mbps with 4 DS channel bounding (DOCSIS)
  222.48(+200) Mbps with 4 DS channel bounding (Euro DOCSIS)
  Bandwidth:
  6MHz (DOCSIS, DOCSIS-J)
  8MHz (EuroDOCSIS)
  6/8MHz (DOCSIS and EuroDOCSIS dual mode)
  Frequency Range:
  50 to 1002 MHz DOCSIS
TRANSMITTER
  Modulation:
QPsk, 8/16/32/64/128,256QAM
  Data Rate:
30Mbps / TDMA
35Mbps / SCDMA
  Frequency Range:
5 to 42 MHz edge to edge
5 to 65 MHz edge to edge (DOCSIS)
(Optional upstream frequency range 5-85 MHz ; Extended Upstream Frequency Range)
  Bandwidth:
TDMA: 1600, 3200, and 6400 kHz
S-CDMA: 1600, 3200, and 6400 kHz
Optional pre-3.0-DOCSIS operation,
TDMA: 200, 400, and 800 kHz
  Output Signal Level:
8 to +58dBmV (QPSK)
8 to +54dBmV (64QAM)
8 to +54dBmV (32QAM)
8 to +53dBmV (S-CDMA)
Voice / Fax
  Audio Codes:
G.711, G.729A, G.723.1, etc.
NETWORK PROTOCOL
Standards
  IP
  TCP
  UDP
  ARP
  ICMP
  DHCP
  TP
  TFTP
  SNMP
  HTTP Routing
  DNS relay
  DHCP server
  RIP I&II
Internet Sharing
  NAT
  NAPT
  DHCP server
  DNS relay
OPERATING TEMPERATURE
0˚ to 40˚C
STORAGE TEMPERATURE
-50˚ to 70˚C
OPERATING HUMIDITY
10% to 90% RH
STORAGE HUMIDITY
5% to 95% RH
EMISSION (EMI) CERTIFICATIONS
  FCC class B,
  CE mark class B
Ürünler | Destek  | Haberler  | Hakkında |
