DCS-3110EOL EOS
Tanımlama
DESIGNED FOR POWERFUL SURVEILLANCE
The DCS-3110 Megapixel Network Camera is designed for business use. A 1.3 Megapixel progressive scan CMOS sensor enables capture of high-resolution images on a wide coverage area, making it suitable for sensitive motion detection as an indoor/outdoor security solution. The DCS-3110 uses its SoC (system-on-chip) to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. Furthermore, this camera supports MPEG4 multicast streaming, letting users view content by subscribing to a multicast IP address on the network. The DCS-3110 can also be connected to a variety of external devices such as IR-sensors, switches and alarm relays making it an ideal solution for high quality viewing and reliable recording during the day or night.
WATCH LIVE VIDEOS FROM A 3G DEVICE
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Users are offered a fexible and convenient way to remotely monitor a home or offce in real time, anywhere within the 3GPP service area.
EASY TO SETUP WITH WIRED PoE ACCESS
For effective surveillance in and around a building, the DCS-3110 comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module for fexible deployment. It can connect directly to a PoE Ethernet switch without the need for a power cable, providing users the freedom to place the camera anywhere they want, including high walls and hard to see locations.
D-Link’s D-ViewCam software allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts and be instantly informed of unusual activities. In addition, this network camera supports the universal plug-n-play feature, which allows computers running on Windows 2000/xP/Vista to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g.mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
1 Camera must be connected to a multicast-enabled router
Genel Özellikler
NETWORK PROTOCOL SUPPORT
IPv4, TCP/IP, RTSP/ RTP/ RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, IGMP, Samba client, IP Filtering, 3GPP
NETWORK INTERFACE
+ IEEE 802.3/802.3u 10/100BASE-Tx Ethernet port
+ Supports half/full-duplex operations
+ Supports 802.3x Flow Control in full-duplex mode
+ Supports IEEE 802.3af PoE
VIDEO ALGORITHM SUPPORT
+ JPEG for still image
+ Compression: MJPEG & MPEG-4
+ Streaming: simultaneous dual-streaming
+ MPEG-4 streaming over UDP, TCP, or HTTP
+ MPEG-4 multicast streaming
+ MJPEG streaming over HTTP
VIDEO RESOLUTION
+ MJPEG video with resolution up to 1280x1024 (1.3 Megapixel)
+ MPEG-4 video with resolution up to 640x480 (VGA)
+ Up to 30fps at 176 x 144
+ Up to 30fps at 320 x 240
+ Up to 30fps at 640 x 480
+ Up to 8 frames at 1280x1024
VIDEO FEATURES
+ Adjustable image size, quality, and bit rate
+ Time stamp and text overlays
+ 3 confgurable motion detection windows
+ Flip & mirror
+ Confgurable brightness
+ AGC, AWB, AES
VIDEO BIT RATE
20k to 4M
SENSOR & LENS SPECIFICATIONS
+ 1/4” 1.3 Megapixel progressive color CMOS sensor
+ 6 mm megapixel lens, F1.6
+ Removable IR-cut flter: Auto/Schedule/Manual
+ Minimum illumination: 1.5 Lux, F2.0
EVENT MANAGEMENT
+ Motion detection weekly schedule
+ Event notifcation and upload snapshots/video clips via HTTP, SMTP, or FTP
+ Multiple HTTP, SMTP, or FTP server setups
+ Multiple event notifcation setups for fexible application
+ Multiple recording methods for easier backup
SECURITY
+ Administrator and user group protected
+ Password authentication
+ HTTP and RTSP digest encryption
SURVEILLANCE SOFTWARE FUNCTIONS
+ Remote management/control of up to 32 cameras
+ Viewing of up to 32 cameras on one screen
+ Supports all management functions provided in web interface
+ Scheduled motion triggered, or manual recording options
REMOTE MANAGEMENT
+ Confguration accessible via web browser
+ Take snapshots/video clips and save to CF card, local hard drive or NAS via web browser
+ Camera live viewing for up to 10 clients*
SYSTEM REQUIREMENTS
+ Operating System: Microsoft Windows 2000, XP, Vista
+ Browser: Internet Explorer, Firefox, Netscape, Mozilla, Opera browser
3GPP MOBILE SURVEILLANCE
Handsets with 3GPP player with following software support:
+ Packet Video Player 3.0
+ QuickTime 6.5
+ Real Player 10.5
AUDIO
+ Compression and bit rate:
- GSM-AMR speech compression, bit rate: 4.75 kbps ~12.2 kbps
- MPEG-4 AAC audio encoding, bit rate: 16 kbps ~128 kbps
+ Interface: built-in microphone, external microphone input, external speaker output
+ Supports two-way audio by SIP protocol
+ Supports hardware and software audio mute
EXTERNAL DEVICE INTERFACE
+ One D/I and one D/O for external sensor and alarm
+ RS485 interface for external scanner
+ DC12V output for external accessory
DIAGNOSTIC LED
2 color LED
FRONT-END STORAGE
CF card slot for local recording of MP4 fles
POWER INPUT
100 - 240VAC, 50/60Hz, 12VDC, 1.25A
POWER CONSUMPTION
Max 4 W
.jpg)
.jpg)
