DVS-104EOL EOS
M-JPEG 4-channel Video Server
Tanımlama
Transform Analog Video Into Images for Live Access Over Intranet or Internet The DVS-104 is a MJPEG technology-based video server designed for professional IP surveillance application. It transmits up to four analog video streams over Ethernet or modem and provides additional video outputs for connection of analog monitors or traditional multiplexers. With 4-channel analog-to-digital image transmission, this video server provides a highly cost-effective device ideal for installation of a multi-camera surveillance system.
Save Money & Get Benefits of Digital World
You have invested time and money to install an analog surveillance system in your building, with analog cameras, multiplexers, time-lapse recorders, cabling and control room. There are drawbacks such as poor quality video, worn out tapes, video recorders that constantly need servicing, and no possibility to access live images when you are outside the building. By adding a DVS-104 video server, you can turn your cameras into a digital system and have images stored on a hard disk at a remote location for convenience and security purposes. You don't need to buy and change video tapes, or service the video recorder. Digital storage also reduces the risk of image degradation and provides quick and easy search capabilities.
Protect Previous Investments
The DVS-104 integrates easily with your existing analog CCTV (closed circuit television) system. You can get all the digital benefits without scrapping your investment in an analog system.
Remote Access
The DVS-104 digitizes analog video signals and distributes digital images directly over an IP-based network, effectively turning your analog cameras into network cameras and enables you to view live images from a Web browser . The DVS-104 allows you to remotely view live digital images derived from your analog cameras at any time, from any location using a networked computer. Y ou can check on alarms while on the road or from the convenience of your own home. Images from an alarm event could be easily distributed via computer networks to many people in different locations for further examination.
Easy to Install & Use
With the DVS-104, you can have a professional surveillance application up and running in minutes. It is easy to install. Simply plug your analog cameras into the server and images can be transmitted via a LAN, DSL, or analog modem. All that is needed on the receiving end is a networked computer with a Web browser . With a network computer is already in place, you save on the infrastructure cost.
Connectable to Control Equipment
Through the built-in RS-232 serial ports, you can control equipment such as Pan/Tilt/Zoom cameras. Inputs can be used to trigger the server to start transmitting images. The DVS-104 can also be connected to special cameras such as super sensitive black/white cameras, miniature cameras or microscope cameras.
Genel Özellikler
Hardware
RAM
16M bytes SDRAM
ROM
2M bytes FLASH ROM
Video Connectors
- Input: 4 BNC connectors for cameras
- 75-ohm terminator for each channel
- Output: 4 BNC connectors for loop-through video outputs
Serial Port
- 2 DB-9 RS-232 interfaces, max. 115200bps
- 1 RS-485 interface to share with the first RS-232 for PTZ camera control
- Second RS-232 can be used for external modem
Auxiliary Power
- Input: 50 to 16000Hz
- Output: more than 60dB
Diagnostic LEDs
- 3 LEDs for network activity, link speed, half/full duplex
- 3 LEDs for system power, heartbeat, and network interface
General I/O
- 4 opto-isolated sensor inputs, max. 12VDC 50mA
- 2 relay outputs with NC/NO, max. 24VDC 1A/125VAC 0.5A
Network (Ethernet)
10/100BASE-TX port
Firmware
Operating System
Industry-standard real-time O.S. pSOS+
Network Protocols
- Standard TCP/IP protocol stack
- HTTP, SMTP , FTP, Telnet, NTP , DNS, DHCP
Service
- HTTP web server
- FTP server and client
- SMTP client
- Telnet server
Network Feature
Adjustable bandwidth limit
Video Algorithm
- JPEG compression
- Motion JPEG with boundary information
Image size
- NTSC: 176 x 112, 352 x 240, 704 x 480
- PAL: 176 x 144, 352 x 288, 704 x 576
Video Quality
5 levels of Normal, Standard, Good, Detailed, Excellent
Video Features
- NTSC: 30 frames/second
- PAL: 25 frames/second
- Flip and mirror for installation
- Built-in motion detection with sensitivity and percentage
Viewing System Requirements
- Viewer: Web browser with server push capability, ActiveX control plug-in for Microsoft Internet Explorer
- Protocol: Internet TCPIP protocol
- Operating system: Windows 98 SE, ME, NT 4.0, 2000, XP
- Browser: Internet Explorer 4.0 or above, Netscape Communicator 4.0 or above
Bundled Surveillance Software Features
- Operates in Windows environment
- Four-channel software DVR
- Full screen display
- Remote management and configuration
- Simultaneous real-time monitoring and recording
- 3 types of recording supported: event-triggered, scheduled, manual
- Warning provided as hard disk space approaching limit
- Scheduled backup
- Remote control of general I/O devices
- Flash speed time and event searching on playback
- Fast/slow shuttle playback
- Simultaneous display of multiple events on single screen for preview
- A VI format export
Çözümler
Sipariş Bilgisi
DVS-104     M-JPEG 4-Channel Video Server
Görseller
DVS-104
Front view
İndir
Destek Merkezi
