DCS-6111EOL EOS
Day&Night network camera with WDR sensor
Tanımlama
POWERFUL DAY & NIGHT SURVEILLANCE
The DCS-6111 is a f xed dome type network camera designed to target middle market. It uses the WDR VGA Progressive CMOS technology for better performance under different lighting conditions delivering exceptional picture quality. The Wide Dynamic Range capability achieves high resolution, more detailed images in high contrast lighting conditions (for example, strong backlight) and signif cantly improves the quality of real-time videos. The DCS-6111 uses D-Link’s System-on-Chip (SoC) products to provide high quality video compression in MPEG-4 and Motion JPEG formats. The DCS-6111 also incorporates an auto-iris varifocal lens equipped with IR LEDs that offers more fl exibility and enhanced security, thus making it an ideal solution for 24/7 hour surveillance.
WIDE DYNAMIC RANGE (WDR) APPLICATIONS
The Wide Dynamic Range (WDR) function of a camera provides clear images even under back light circumstances where intensity of illumination can vary excessively. DCS-6111 is recommended for extreme high-contrast environments. For example, when placed on the inside of the room, the DCS-6111 will be able to see through the intense sunlight or artif cial light coming in. This makes it an ideal solution for security applications.
VARIOUS INSTALLATION METHODS AT DIFFERENT ANGLES
The DCS-6111 has a unique built-in three axis mechanism that can be drop-mounted from the ceiling for an unobtrusive look, or mounted on a wall, all with the same housing design. For optimal detection, the DCS-6111 is recommended for indoor ceiling mounting, to prevent possible damage that maybe caused by a burglar.
WIRED PoE ACCESS
For effective surveillance in and around a building, this camera comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module, which eases the installation process and also gives users the freedom to place the camera anywhere. In addition, the 10/100BASE-TX Ethernet port is also provided for convenient Ethernet connection or broadband internet gateway with router.
SMART & EASY TO USE
The software allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts to be instantly informed of unusual activities. Fixed dome cameras usually uses f xed focus lens, but the DCS-6111 also has a vari-focal lens. Vari-focal lens provides easier installation process because the board lens of dome camera is not like CS/C mount lens, it is not changeable. Drop ceiling bracket is another alternative option for an installation method. In addition, this Network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows 2000/XP/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
Genel Özellikler
NETWORK PROTOCOL SUPPORT
+ IPv4, IPv6, TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, IGMP, Samba Client, IP Filtering, 3GPP, LLTD
BUILT-IN NETWORK INTERFACES
+ 10/100BASE-TX Ethernet port, RJ45
VIDEO ALGORITHM SUPPORT
+ JPEG for still images
+ MPEG4/MJPEG dual format compression
+ Simultaneous dual-streaming
+ MPEG-4 streaming over UDP, TCP, or HTTP
+ MPEG-4 multicast streaming
+ MJPEG streaming over HTTP
+ Supports 3GPP mobile surveillance
+ Camera live viewing of up to 10 clients
VIDEO RESOLUTION
+ MPEG-4/MJPEG video resolution up to 640x480 (VGA)
+ Up to 30fps at 176 x 144
+ Up to 30fps at 320 x 240
+ Up to 30fps at 640 x 480
VIDEO FEATURES
+ Adjustable image size, quality and bit rate
+ Time stamp and text overlays
+ 3 confgurable motion detection windows
+ 5 confgurable privacy masks
+ Flip & mirror
+ Confgurable brightness, saturation, contrast
+ Adjustable AGC level, AWB and AES
AUDIO
+ Compression and bit rate:
- GSM-AMR speech compression, bit rate:
4.75 kbps ~12.2kbps
- MPEG-4 AAC audio encoding, bit rate: 16 kbps ~128 kbps
+ Interface: external microphone input, external speaker output
+ Supports two-way audio by SIP protocol
+ Supports hardware and software audio mute
VIDEO BIT RATE
20K to 4M
CAMERA SPECIFICATIONS
+ 1/4” WDR VGA CMOS sensor
+ 3.3-12mm vari-focal lens, F1.4-F2.9
+ Built-in IR-cut removable (ICR) flter:
Auto/Schedule/Manual Settings
+ Minimum illumination: 1.5 Lux @ F1.4
IR LED
+ 20M illumination distance with 12 LEDs and light sensor
EVENT MANAGEMENT
+ Motion detection by weekly schedule
+ Event notifcation and upload snapshots/video clips via HTTP,
SMTP or FTP
+ Multiple HTTP, SMTP, or FTP server setups
+ Multiple event notifcation setups
+ Multiple recording methods for easy backup
REMOTE MANAGEMENT
+ Confguration accessible via web browser
+ Take snapshots/video clips and save to local hard drive or NAS via web browser
SECURITY
+ Administrator and user group protected
+ Password authentication
+ HTTP and RTSP digest encryption
+ HTTPS streaming2
+ Remote client access allow/deny list
SURVEILLANCE SOFTWARE FUNCTIONS
+ Remote management/control of up to 32 cameras
+ Viewing of up to 32 cameras on one screen
+ Supports all management functions provided in web interface
+ Scheduled motion triggered, or manual recording options
SYSTEM REQUIREMENTS
+ Operating System: Microsoft Windows 2000, XP, Vista
+ Browser: Internet Explorer, Firefox, Netscape, Mozilla, Opera
EXTERNAL DEVICE INTERFACE
+ D/I and D/O for external sensor and alarm
NETWORK INTERFACE
+ IEEE 802.3/802.3u 10/100BASE-TX Ethernet port
+ Supports half/full-duplex operations
+ Supports 802.3x Flow Control in full-duplex mode
+ Supports IEEE 802.3af PoE
Çözümler
Sipariş Bilgisi
DCS-6111 Day&Night network camera with WDR sensor
Görseller
DCS-6111
Front view
İndir
Destek Merkezi
