Hızlı Arama
Ürün Özellikleri:
Full HD Fixed Dome Network Camera
Genel Özellikler:
Fiziksel Özellikler
Genel Özellikler:
Hardware Profile
• 1/2.7” Full HD progressive megapixel CMOS sensor
• Fixed lens, 4 mm F1.5 with 77.4 degree horizontal viewing angle
• Digital Zoom 16X
• 128 Mbytes of flash memory
• 256 Mbytes SDRAM
• Minimum illumination: 0.12 lux/F1.5
Image Features
• Configurable image size, quality, and bit rate
• Time stamp and text overlays
• 3 configurable motion detection windows
• ePTZ function
• 5 configurable privacy masks
• Flip & mirror
• Configurable white balance, shutter speed, brightness, saturation, contrast, sharpness
Video Compression
• H.264/MPEG4/MJPEG dual format compression simultaneously
• JPEG for still image
• H.264/MPEG-4 multicast streaming
Video Resolution
1920x1080 @ 15 fps, 1280x1024 @ 20 fps, 1280x720 @ 30 fps, 640x480 @ 30 fps, 320x240 @ 30 fps, 176x144 @ 30 fps
Audio Features
• GSM-AMR speech encoding, bit rate: 4.75 kbps to 12.2 kbps
• MPEG-4 AAC audio encoding, bit rate: 16 kbps to 128 kbps
• Supports two-way audio and audio mute
Network Protocols
IPv4, IPv6, TCP/IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP/HTTPS, Samba Client, PPPoE, UPnP Port Forwarding, RTP/RTSP/RTCP, IP filtering, 3GPP, LLTD, CoS/QoS, SNMP, IGMP, 802.1x
Security
Administrator and user group protection
Password authentication
• HTTP and RTSP digest encryption
• HTTPS streaming
• Remote client access control
System Requirements
• Operating system: Microsoft Windows 7, Vista, XP, 2000
• Browser: Internet Explorer 6 or higher, Chrome, Firefox, Safari
• D-ViewCam™ System
Requirements for Web Interface
• Operating System: Microsoft Windows 7, Vista, XP
• Web Browser: Internet Explorer 6 or higher
• Protocol: Standard TCP/IP
Event Management
• Motion detection
• Tamper Detection
• Event notification and upload snapshots/video clips via HTTP, SMTP or FTP
• Multiple event notification
• Multiple recording methods for easy backup
• Supports multiple HTTP, SMTP and FTP servers
Remote Management
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive or NAS via web browser
Surveillance Software Function
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Supports all management functions provided in web interface
• Scheduled motion triggered, or manual recording options
Supported PDA, Mobile
• Phones, and Software
• Handsets with 3GPP player, Quick Time 6.5, Real Player 10.5, Windows 7, Vista, XP, 2000
External Device Interface
• DI and DO for external sensor and alarm
• External audio input (MIC in)
• External audio/video output (AV out)
• TV system switch (NTSC/ PAL)
• MicroSD card slot
Fiziksel Özellikler
Power Input
12 V DC 1.25 A, 50/60 Hz, IEEE 802.3af PoE
Max. Power Consumption
4.4 W
Operating Temperature
-0 to 40 ˚C (32 to 104 ˚F)
Storage Temperature
-20 to 70 ˚C (-4 to 158 ˚F)
Humidity
90% non-condensing
Weight
466 g (1.03 lbs)
Certifications
CE (Class A), CE LVD (EN60965-1), FCC (Class A), ICES-003, C-Tick
Ürünler | Destek  | Haberler  | Hakkında |
