Hızlı Arama
Ürün Özellikleri:
Professional Network Video Recorder (NVR) with two drive bays
Genel Özellikler:
Fiziksel Özellikler
Standards
• IEEE 802.3/u/z
• Auto MDI / MDI-X
• SATA I, II
HDD (Hard Disk Drive)
• Monitor your hard drive and control via PC
• Reformatting the disk
• RAID 0, 1
• JBOD
Safety
• Castle (HD)
• Security lock (per device)
Performance
Flash ROM
128 MB
RAM
256 MB DDR II
Network interface
Port LAN Gigabit Ethernet (10/100/1000 Mbit / s)
I / O Ports
• RJ-45 port
• DC-in jack
• USB port to update the status of the UPS
The software features
Operating system
Linux
Supported Cameras
• Supports all network cameras D-Link. Includes support for automatic detection and megapixel resolution
• Supports network camera brands, including D-Link, Axis, Panasonic, Sony, Mobotix, Arecont Vision, IQinVision, Cisco and Acti
Write Performance
• Max. characteristics (only mode NVR):
  - H.264 1080P (data rate): 90 Mbit / s
  - H.264 720P (data rate): 90 Mbit / s
  - MJPEG 1080P (frame rate): 90 frames / s
  - MJPEG 720P (frame rate): 192 frames / s
• Max. performance mode (NVR + File Server):
  - H.264 1080P (data rate): 68 Mbit / s
  - H.264 720P (data rate): 68 Mbit / s
  - MJPEG 1080P (frame rate): 70 frames / s
  - MJPEG 720P (frame rate): 150 frames / s
Camera Search
UPnP
Record audio and video
Record synchronized audio and video
Compression Format
H.264, MPEG-4, M-JPEG (for the camera)
Customize video
Resolution, quality, frame rate, enable audio, go to camera interface
Record Type
Scheduled recording, manual and event (DI-trigger, motion detection sensor with camera)
Remote viewing of live video
• Remote viewing of live video through Internet Explorer
• The maximum number of simultaneous channels you watch: 9
Managing a remote video viewing in real time
View the video in real time, preset / go (preset / go), patrol, focus, function PTZ (pan / tilt / rotation), freeze-frame, full-screen mode, digital zoom
Controlling the remote playback
• Play with the functions of a conventional fast, fast forward / rewind and step forward / rewind
• Intelligent Detection Smart Search: General Motion (basic movement), Missing Object (missing object), Foreign Object (foreign object), Camera Occlusion (Blackout camera), Lose Focus (out of focus)
Remote Playback
• Remote playback via Internet Explorer and NVR-client
• Playback system with timeline GUI, search by event, area, cameras, date and time
• Internet Explorer and NVR-client supports simultaneous playback of four channels
The re
Automatic overwrite in case of filling the space on your hard drive
Export Files
• Export video files in AVI or ASF
• Export images in BMP or JPG
User Account
Ability to create additional user accounts to allow the user access to the system and the definition of authorization for camera channels, PTZ, etc.
DDNS
Support DDNS-Server D-Link
Two modes reset to factory settings
• Reset the firmware to factory settings through the GUI
• Hardware Reset button to factory settings (you must hold for 5 seconds)
The system time
Setting the system time (D-Link NTP, input time, sync with your computer, saving time)
Remote backup
• Remote software can create a backup copy of the raw data on the secondary storage device
• Backing up data to a remote FTP-server on a daily schedule
System Status
• Camera status
• System Status
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP-server
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-Client (D-Link)
• SMTP-client
• HTTP-server
• PPPoE
• UPnP
• Filtering IP-addresses
• Samba-server
User interface
• Web-browser HTTP
• Internet Explorer 7 or above
• NVR Search Utility
• Multi-language GUI
Scope of delivery
• Network Video Recorder with two drive bays
• Power Adapter
• Ethernet-cable
• Quick Installation Guide
• The holder of the power cable
• CD-ROM with software and product documentation
Fiziksel Özellikler
The power adapter
12 V DC / 4 A
The maximum power consumption
25.20 W
The maximum power consumption in standby mode
0,234 W
Operating temperature
From 0 ° to 55 ° C
Storage temperature
-20 ° to 70 ° C
Humidity
From 5% to 90% (non-condensing)
Measurements
115 x 146,4 x 178,5 mm
Weight
0,875 kg
Certifications
• CE
• FCC
• RoHS
Ürünler | Destek  | Haberler  | Hakkında |
