Hızlı Arama
Ürün Özellikleri:
Full HD Mini Fixed Dome Network Camera
Tanımlama:
Tanımlama:
The DCS-6210 Full HD Mini Fixed Dome Network Camera is an industry rated vandal proof and weatherproof camera suited to a wide range of traditionally difficult deployment scenarios.
Built for Tough Environments
Specially designed for use in challenging environments the DCS-6210 has a toughened metal, industry-certified IK-10 (vandal-proof ) and IP-66 (weather-proof ) housing. This means that it is able to withstand sudden high impact, and adverse weather conditions. Additionally, the DCS-6210 carries a Power over Ethernet (PoE) port which allows you to connect the camera to your network and power it through a single cable. This both expands and simplifies your  deployment options by doing away with the need for a nearby power outlet, making deployment on ceilings much easier.
Surveillance in Full High Definition
The DCS-6210 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 1080p Full HD. This gives you sharp, high-resolution pictures and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera’s video so you can survey a large area easily.
A Complete, Expandable Surveillance Solution
The DCS-6210 is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Built for Versatility
The DCS-6210 comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. It’s 3 axis lens mounting allows you to position it perfectly, while its motion detection capabilities allow it to automatically record video and send you a notification when motion is detected.
Ürünler | Destek  | Haberler  | Hakkında |
