Hızlı Arama
Ürün Özellikleri:
802.11n wireless network camera with night mode and support for the H.264 codec
Tanımlama:
Wireless 802.11n Network Camera DCS-933L with the possibility of night shooting and support for the H.264 codec is a versatile and unique solution for your small office or home. In contrast to standard Web-camera DCS-933L is a complete system with a built-in CPU and Web-based server that transmits high quality video images.
Round the clock surveillance
DCS-933L is a stand-alone camera that does not require any special hardware or software and can work on their own, even without a computer. Using the Camera DCS-933L and Internet connection lets you send a notification to snapshots or video clips via e-mail when motion or sound. You can set up motion detection area, for example, the entrance to the building, and you can set a threshold sound level above which will be fixed this week. Built-in infrared illumination allows to conduct surveillance at night at a distance of 5 meters.
Multifunctional surveillance system
The supplied software DCS-933L D-ViewCam software allows you to extend the functionality of the camera to create a complete video surveillance system. With the D-ViewCam can centrally manage multiple network cameras (up to 32 cameras and up to 64 users), to record a wide range of functions, including recording triggered sensors on a schedule or manually.
High speed data transmission, a large range of your wireless network
Thanks to the 802.11b/g/n wireless connection and jack Ethernet / Fast Ethernet can be easily integrated into an existing network camera. Repeater mode allows to extend the range of wireless network, which helps to eliminate the low-band signal, and to easily add other wireless devices in the network.
Constant remote access to video using a cloud service mydlink
Support Camera DCS-933L mydlink ™ service makes monitoring your home or office easier, more convenient and allows you to stay connected regardless of their location. Access to the mydlink service is available through the Web-browser, as well as additional mydlink applications for mobile users. Mydlink app allows the user using Wi-Fi, 3G or 4G connection to quickly and easily view the video from the camera.
Ürünler | Destek  | Haberler  | Hakkında |
